Go Back   Home > Forums > General Interest > Car Audio
Old 8th June 2010, 03:34 AM   #1
tony711 is offline tony711  United States
Question no sound coming out of amp
amplifier turns on and power light dims wen bass (would hit) but no sound is coming from it n e 1 have an idea how to fix it? ive took it apart and soldered some things that were a bit burnt and thats how i got the power light to now dim with the music but still no sound....... c oiuld it be a problem with the speaker output connections directly or something more advanced like diodes and transistors???
Old 8th June 2010, 04:23 AM   #2
If the lights dimmed only when there was a strong signal sent to the amp, the speaker or the wiring was likely shorted.
Old 8th June 2010, 01:31 PM   #3
well ive tried a few different subs and the same thing happens with it each time... wen i first received the amp it did absolutely nothing but power on, and so i took it apart and found a couple burnt spots then re-soldered them, now it seems like a normal operating amp but no sound comes out.... ive tried tapping the inputs with a small screwdriver to c if maybe the inputs were messed up but the power light dims as if i were putting music through it like various amps ive had where the power light will dim synchronized with the beat... wat should i check for next??? n e ideas?
Old 8th June 2010, 05:33 PM   #4
What was burned?
What do you mean you tapped the inputs?
Old 9th June 2010, 05:47 AM   #5
not sure wat was burned but it fixed the amp to where the light dims wen the bass was going thru it just no sound actualy coming out....
and if u turn on an amp and tap a small screwdriver or something metal into the center of an audio input jack it will thump in the subwoofer
Vintage Pioneer SA-6200 sound problem coming from power amplifier assy! SeMu Solid State 8 4th September 2011 09:01 AM
Scratchy clicky noise coming from homemade 6L6 tube amp Jim5150 Tubes / Valves 4 25th June 2009 10:53 AM
The New Sonic Amp is coming Pano Class D 1 11th November 2005 11:37 AM
What's that "blopping" sound coming out from my dipole? sqlkev Multi-Way 29 2nd November 2005 01:36 PM
Page generated in 0.08307 seconds (70.94% PHP - 29.06% MySQL) with 10 queries
