Amp turning on without remote voltage. Amp turning on without remote voltage. - Page 6 - diyAudio
Old 6th June 2010, 07:53 AM   #51
catfishermike is offline catfishermike  United States
Perry,my son decided to help me out and clean the house,doing so he threw out the diagram of the parts removed.The only thing I cant recall is U04,D14,D12,Uo3,D13,D15.Would you happen to know which components went in these locations.
Old 6th June 2010, 06:51 PM   #52
Perry Babin is offline Perry Babin  United States
If U03 and U04 are the regulators, the L7812 and L7912 are likely good subs. The center leg of the L7812 will be directly connected to the secondary center tap or the negative speaker terminal.
For the rectifiers, the FEP16DT and FEP16DTA are probably good subs. The FEP16DTA will go in the locations where the diode symbols on the board are facing away from each other.
If you're lucky, the engineer from Kicker will see this and respond. He'll be able to provide the exact part numbers.
Old 6th June 2010, 10:38 PM   #53
It is using Kia 7812A AND kia 7912PI.I cant remember which one went where.And YG225C2 and YG225N2,2 of each of those.I cant remember which ones go where.This amp is using 3205's and IRF640 and 9640's.As far as I can tell they all test good.
Old 6th June 2010, 10:56 PM   #54
I misread the message. I thought he threw out the parts.
The following datasheet shoes the symbols for the diodes. Match the symbols to the part numbers.
YG225C2 pdf, YG225C2 description, YG225C2 datasheets, YG225C2 view ::: ALLDATASHEET :::
The center leg of the kia7812 will go to the secondary ground. The 7912 goes on the other side of the amp.
Amp turning on without remote voltage.Hide this!Advertise here!
Amp turning off.... Jonny Hotnuts Car Audio 1 15th May 2008 10:02 PM
This is how my new amp is turning out.. nikwal Solid State 5 7th October 2007 01:34 PM
Pop from amp when turning off speed3 Tubes / Valves 2 25th September 2007 04:59 PM
DC offset when turning amp off.... ghisdal Chip Amps 4 26th August 2007 06:44 PM
voltage to look for on an amp remote lead? (A/D/S PQ8 spec) }"{ Solid State 0 3rd July 2006 08:51 PM
Copyright ©1999-2017 diyAudio
