Amp turning on without remote voltage.
Old 6th June 2010, 03:40 AM   #21
catfishermike is offline catfishermike  United States
checked it,OL from 2-3.
Old 6th June 2010, 03:58 AM   #22
Perry Babin is offline Perry Babin  United States
It's strange that removing this transistor broke the connection but the transistor isn't defective and the voltage feeding it isn't driving the transistor on.
Power the amp up including remote and measure the voltage on the pads of this transistor again.
Old 6th June 2010, 04:23 AM   #23
12.63-.56-4.78 and climbing slowly.And from the pic you posted it would be.
3 2 1
Old 6th June 2010, 04:43 AM   #24
Did you list the other voltages in reverse order also. That makes a huge difference.
Old 6th June 2010, 04:45 AM   #25
yes I did Perry.
Old 6th June 2010, 05:07 AM   #26
Check Q02 the same way.
Old 6th June 2010, 05:16 AM   #27
voltage=3=11.5-2=0-1=0.69
ohms=ol any way i place the leads
Old 6th June 2010, 05:21 AM   #28
What's the voltage without remote voltage applied?
Old 6th June 2010, 05:26 AM   #29
11.96 on 3-0 on 2 and 1
Old 6th June 2010, 05:40 AM   #30
If you have ~12.6v on the B+ terminals (as you did earlier), remove this transistor and check it out of the board. The resistance from 2-3 should read OL. Check it then reverse the probes and check it again.
Amp turning on without remote voltage.Hide this!Advertise here!
Amp turning off.... Jonny Hotnuts Car Audio 1 15th May 2008 11:02 PM
This is how my new amp is turning out.. nikwal Solid State 5 7th October 2007 02:34 PM
Pop from amp when turning off speed3 Tubes / Valves 2 25th September 2007 05:59 PM
DC offset when turning amp off.... ghisdal Chip Amps 4 26th August 2007 07:44 PM
voltage to look for on an amp remote lead? (A/D/S PQ8 spec) }"{ Solid State 0 3rd July 2006 09:51 PM
