Go Back   Home > Forums > General Interest > Car Audio
Old 4th June 2010, 03:45 AM   #1
Default Scosche vr3
Im working on this amp i found 2 bad outputs in it. I removed them from the board and powerd the amp up.
Its producing negative rail voltage. The positive rail voltage starts out at 27 volts then starts decreasing so like i start with 27 volts then it goes to 20 volts then 15 volts all the way down to 3 volts then it starts over agin 27 volts then decreases.
Wondering what might cause this problem and where do i need to check?
Old 4th June 2010, 05:21 AM   #2
I did somemore checking and This is what i got for voltages
Power Supply Fets IRFZ44N's
1:0
2:13.92
3:0
No wave form on gates.
TL494
1:1.52
2:3.64
3:4.72
4:4.20
5:1.45
6:3.62
7:0
8:13.92
9:0
10:0
11:13.92
12:13.92
13:5.01
14:5.01
15:0
16:5.01
Old 4th June 2010, 10:53 AM   #3
It sounds like the power supply is coming up and is sensing a problem so it shuts down. The voltage drops slowly as the filter caps discharge.
I think you have the voltage on 15 and 16 reversed. Re-check that.
The voltage on pin 4 is too high also.
A photo of the inside of the amp would be helpful. I've never worked on one of these.
Old 4th June 2010, 05:04 PM   #4
jol50 is offline jol50  United States
DC offset is one thing, otherwise follow the protection circuits back to see what is shutting it down but that is harder to do I usually fire them up with the meter on different things to catch the obvious such as another bad output.
If you see gate voltage to the PS fets and then it goes away its near always protecting. Does it have a protect LED?
Old 4th June 2010, 05:05 PM   #5
Perry,
I had some leaking outputs in this amp with them removed it powers up fine.
The amp is using IRF540's for the outputs. Would ^40's work in this amp also or is that not a good idea?
Old 4th June 2010, 05:09 PM   #6
640s?
The 640s are rated for significantly less current. They 'may' be OK for testing but I wouldn't use them as replacements.
Walmart VR3 12" Subwoofer? form109 Car Audio 18 16th August 2010 02:26 AM
Scosche - Any Good ? EdT Multi-Way 1 24th February 2007 06:01 PM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 03:40 AM
Boston VR3 and VR2 speakers vossie Multi-Way 4 8th October 2004 05:10 PM
Audax HM130CO VR3 Matching HT Project MemphisJim Multi-Way 2 11th June 2004 02:22 AM
Page generated in 0.08330 seconds (74.18% PHP - 25.82% MySQL) with 10 queries
