Go Back   Home > Forums > General Interest > Car Audio
Old 10th June 2010, 02:21 AM   #21
babin_perry@yahoo.com
Old 11th June 2010, 07:53 PM   #22
ok
i resoldered the bad looking joints , checked all over for burnt tracks or components , and soldered on 2 bridge wires that perry emailed a link to
its pretty much the same , maybe a tad better but its probably wishfull thinking
Old 12th June 2010, 11:10 AM   #23
To do any further troubleshooting, you'll likely need a signal tracer. If you were in the US, I'd recommend the Radio Shack mini-amplifier but I doubt it's available there. Maybe you can find something similar.
Old 12th June 2010, 02:21 PM   #24
edit..
found one cheap in uk ebay
if i get one , is it likley that i will fix it ? i dont want to spend $$ on equipment then be unable to fix it anyway , if you dont mind maybe a quick outline of what the next step will involve please
thanks again
Old 12th June 2010, 11:08 PM   #25
The mini amp would be used to listen to the signals on the input and output pins of several components (ICs, transistors...) to see if you can find the point where the noise is entering the audio chain. If the problem is internal to the head unit, it's possible that the mini-amp will help track it down but there are no guarantees.
Old 13th June 2010, 07:43 AM   #26
ok i'll get it ordered then..will report back when its in my hands
Old 15th June 2010, 08:08 AM   #27
ok i have the radio shack amp/speaker here now
next step in dummy terms please
Old 15th June 2010, 08:47 AM   #28
Power up the head unit in the vehicle (assuming that the noise was being produced by the charging system in the vehicle) and connect the mini-amp to each channel to confirm that the same channel is noisy with the mini-amp as with the original amplifier.
Old 15th June 2010, 08:59 AM   #29
ok i'll do it...i know its not the charging system
as mentioned before i ran it in the house with a spare car battery and my home hifi amp
Old 15th June 2010, 09:00 AM   #30
If it's not related to the charging system, you can test wherever it's most convenient.
Rockford Power 550x bias issue brandes.cm Car Audio 5 24th November 2009 01:13 PM
LM3886 noise issue zeus_threat Chip Amps 25 15th August 2008 09:26 AM
Rockford RAV DVD1 issue Mr. Old School Car Audio 11 1st January 2008 11:45 PM
Rockford Denford RFX-8250/40 Parts/Mods thatvan Car Audio 1 26th October 2006 03:50 PM
Repairs on my Rockford RFX-8140 Mr. Old School Car Audio 6 24th January 2006 07:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
