noise issue on rockford rfx 8140
Old 4th June 2010, 08:02 AM   #11
steveo3002 is offline steveo3002  United Kingdom
it only has one pair of rca , so the sub is ran via a Y piece splitter , ive tried running just the one amp with no Y piece and its the same
Old 5th June 2010, 04:38 PM   #12
okay heres some pics inside
1st one...looks like someone might have had a go at the left channel , in person it doesnt look terrible but the pics pretty much say its been tampered with
next this looks like a dry joint...might re heat that one?
some deposits on the board ...should i clean that , if so how?
couple of general guts pics incase you spot anything
Old 6th June 2010, 07:08 PM   #13
do the pics help anyone
can take some more in detail if i know what to take
Old 6th June 2010, 07:27 PM   #14
Perry Babin is offline Perry Babin  United States
You need to clean the corrosion and closely examine the resistors, capacitors and ICS (and their connections) with a high power lighted magnifying glass. You can clean it with rubbing alcohol and a cotton swab.
You also need to add additional solder to the solder joints on the connector, desolder them, inspect the copper on the board (to determine if it's intact) and then resolder the connections. When you do this, touch the soldering iron to the tip of the connector pin only. Allow the pin to conduct the heat to the board. The copper on this board is VERY thin and VERY easily damaged. Touching only the connector pin will virtually eliminate the possibility that the board will be damaged.
I doubt that any of this will solve the problem but you may find a defective component or solder connection.
Old 6th June 2010, 07:47 PM   #15
yeah im thinking someone else soldered those pins in the hope of fixing it
any tips on what to look for on the components when i use a mag glass ? apart from being burnt and black i have no idea what to look for
thanks again
p.s have contacted rf for the diagrams , but what they sent me doesnt open
Old 6th June 2010, 07:53 PM   #16
What error do you get when opening the file?
Look for solder connections that have deteriorated, damage to the resistor bodies and discoloration of the small SMD capacitors.
Old 6th June 2010, 07:55 PM   #17
the file wont open , its 21 pages and only the first page will show , have asked some buddys to try it and same
ive requested they send it again
Old 6th June 2010, 07:57 PM   #18
Did you try downloading it again. Maybe it was corrupted in the download and the copies you sent to others were corrupted. If you download it again from your email server, maybe you'll get a good copy.
Old 6th June 2010, 08:01 PM   #19
yeah i tried all ways i could think , i let the others log into my account from thier computer and download it themselves
im keen to fix this , so will try and get the file one way or another
Old 9th June 2010, 07:20 PM   #20
rockford insist thier pdf is fully working..my techie buddy tells me its issues thier end
the file is too big to email ...perry if you can give a contact email for yourself i can forward the details to see if it works for you ??
or perry /anyone know anywhere else i might find a schematic diagram?
i have the magnifying glass now , and will inspect the unit carefully over the weekend
noise issue on rockford rfx 8140Hide this!Advertise here!
Rockford Power 550x bias issue brandes.cm Car Audio 5 24th November 2009 02:13 PM
LM3886 noise issue zeus_threat Chip Amps 25 15th August 2008 10:26 AM
Rockford RAV DVD1 issue Mr. Old School Car Audio 11 2nd January 2008 12:45 AM
Rockford Denford RFX-8250/40 Parts/Mods thatvan Car Audio 1 26th October 2006 04:50 PM
Repairs on my Rockford RFX-8140 Mr. Old School Car Audio 6 24th January 2006 08:09 PM
Copyright ©1999-2017 diyAudio
