Go Back   Home > Forums > General Interest > Car Audio
Old 30th May 2010, 07:28 PM   #1
Default what scope to repair car amp ?
Hello everybody
I would like that you help choose a good scope to repair easily a car amplifier please
I'm not rich so i've seen that
Oscilloscope manuel HPS 10 sur CONRAD, Multimètres graphiques, Multimètres
Oscilloscope 610/2 10 MHz sur CONRAD, Oscilloscopes monocanaux analogiques, Oscilloscopes
for security i don't want product already used because i'm newbie
So can you tell me if they are ok for repairing car amp please ? and what i must in the technical caractéristique to have a good scope ?
Thanks a lot in advance
Old 30th May 2010, 08:04 PM   #2
I would choose the CRT based scope. It will have a much better resolution and will make it easier to see distortion and glitches.
Old 30th May 2010, 08:11 PM   #3
Thanks Perry
WHen you talk about crt scope do you talk of this scope ?
if yes ? it will be ok to repair car amp? because it's the less expensive and i don't know if it's good for what i need
Thanks a lot for your confirmation
Old 30th May 2010, 08:13 PM   #4
Yes. That's the CRT based scope. If it's in good working order and can meet the 10MHz spec, it's good enough.
Old 30th May 2010, 08:19 PM   #5
Thanks a lot Perry
You are a great person !
sincerely i Thank you for your help from the beginning
Old 8th June 2010, 07:14 PM   #6
Hello Perry
I will buy a scope to repair the sinuslive amp because i can't buy other amp for the moment
this is the scope Perry
but in the french manual they say:
""The measurement can be performed in circuits that, by design, not
can generate more than 6 amps.""
are you sure that scope is good fo repairing car audio amplifier Perry?
the english manual in english in pdf file
http://www1.produktinfo.conrad.com/d...RAFT_AO610.pdf
Can you confirm me please, this scope is good for repairing amp Perry
because if it's good i buy it
but could you help me to use it please ?
Thanks in advance
Old 8th June 2010, 07:27 PM   #7
I can't find that statement in the english version. Find it and post the page where you find it.
Old 8th June 2010, 07:47 PM   #8
this is the french version of the manual and i have translate in english this information.
it's at page 2 of the manual in: Domaine d’application
• La mesure ne peut être effectuée que dans des circuits qui, de par leur conception, ne
peuvent générer plus de 6 ampères.
• Une utilisation autre que celle décrite dans la présente notice est interdite !
http://www1.produktinfo.conrad.com/d...-oscillosc.pdf
Old 8th June 2010, 08:05 PM   #9
It may be a misprint. No more than a few microamps is passed through the scope. I don't want you to buy it based on what I tell you. I can't see any reason it won't be a perfectly good choice but I've never used that model scope.
Contact the seller. They should be able to definitively answer your questions.
Old 8th June 2010, 09:19 PM   #10
I have difficulties to contact them
I don't know what to do
DIY Car Repair avatar307 The Lounge 6 22nd May 2011 10:19 PM
Trio CS1577A scope repair CY Equipment & Tools 1 9th November 2009 01:33 AM
Car Amp Repair in Memphis?? beco Car Audio 0 8th August 2008 06:10 AM
Car amp repair: Overheated my a/d/s PH15... Tremelune Solid State 0 31st May 2005 04:57 AM
car amp repair question!!!!!!!! sndtch6 Solid State 10 11th April 2004 07:02 PM
Page generated in 0.10488 seconds (81.76% PHP - 18.24% MySQL) with 11 queries
