another performance teknique
Old 30th May 2010, 08:25 PM   #21
timwebb is offline timwebb  United States
yes it showed 0 ohms
Old 30th May 2010, 08:33 PM   #22
Perry Babin is offline Perry Babin  United States
If there is no DC on the outputs of the of the op-amps and the amp works perfectly fine otherwise, it's probably not anything to be concerned about.
Old 2nd June 2010, 05:41 PM   #23
what to look for if there is resistance on the rca jacks
Old 2nd June 2010, 05:43 PM   #24
Does the amp work perfectly except when you turn the gain control?
Old 2nd June 2010, 05:58 PM   #25
yeah i was looking at my friend 600w performance teknique and there is resistance on the rca jacks the amp go into protection when he plug the rca jacks up
Old 2nd June 2010, 06:12 PM   #26
If there is significant resistance between the RCA shield and the non-bridging speaker terminals on most (budget) amps, there is a problem. It's generally either a broken connection on the RCA jacks or an open trace.
Old 8th June 2010, 04:19 AM   #27
sorry perry got another one its a 600 its has a burned trace on the rca ground but the amp goes into protect when the rca's are pluged up?
Old 8th June 2010, 04:23 AM   #28
Does it go into protect when no RCAs are plugged in?
Did you repair the burned trace?
Old 8th June 2010, 04:31 AM   #29
no its good until the rca's are pluged in,and i fixed the trace.
Old 8th June 2010, 04:41 AM   #30
ok i powered the amp up and it dosent come on,the person i got from said it work more problems but the 494 all pins are reading 12.v ? bad chip?
another performance tekniqueHide this!Advertise here!
performance teknique 1200w timwebb Car Audio 10 21st May 2010 03:30 AM
Copyright ©1999-2017 diyAudio
