another performance teknique
Old 30th May 2010, 06:44 AM   #11
timwebb is offline timwebb  United States
it reads
Old 30th May 2010, 07:20 AM   #12
Perry Babin is offline Perry Babin  United States
Are you saying that no pin (2 or 8) reads more than 0.06v DC (amp powered up)?
Old 30th May 2010, 07:34 AM   #13
thats what they read. i tried with a little input and i got like 2v or a little less
Old 30th May 2010, 07:43 AM   #14
Generally, this sort of problem is due to an op-amp with excessive DC on its output. Did you check all of the op-amps in that area?
Does it do this without a signal source connected to the amp?
Old 30th May 2010, 08:55 AM   #15
it reads 0.6 while its on but no input with input it jumps up.all are doing the same thing
Old 30th May 2010, 08:58 AM   #16
Does the speaker pulse in/out when you turn the gain control with no signal source connected?
Old 30th May 2010, 09:17 AM   #17
yes it does
Old 30th May 2010, 11:31 AM   #18
What's the resistance from the RCA shield to either of the non-bridging speaker terminals (no RCAs plugged in)?
Set you meter to the lowest resistance range.
Old 30th May 2010, 03:19 PM   #19
its showing no resistance
Old 30th May 2010, 09:16 PM   #20
No resistance, 0 ohms? If so, that's OK.
another performance tekniqueHide this!Advertise here!
performance teknique 1200w timwebb Car Audio 10 21st May 2010 04:30 AM
Copyright ©1999-2017 diyAudio
