another performance teknique
ok i have another one of these amps and ive changed the output transistors but when i turn the volume up and down the sub pull and pushes out?
What amplifier is this? If it's direct coupled you may be introducing some dc at its input.
performance teknique 1200w 2ch
Changing the volume on the head unit causes the woofer to pulse?
no just when i adjust the gain it pushes and pulls the sub.
Does it do this with the crossover set to full range, high pass and low pass?
low pass
Can you post a photo of the inside of the amp (showing the entire end of the board near the RCA jacks)?
2 Attachment(s)
here they go
Those look like 9 pin op-amps. Do any have more than a fraction of a volt of DC on pin 2 or 8?
| All times are GMT. The time now is 09:25 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
