diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Alpine MRP-F200 (http://www.diyaudio.com/forums/car-audio/167544-alpine-mrp-f200.html)
mike49504 27th May 2010 03:37 AM
Alpine MRP-F200
Ok i have this amp in for repair also. Channel 2 is dead. I hooked the scope up and see that i have the signal on both positive and negative terminals for that channel.
What cause's this again?
Perry Babin 27th May 2010 03:40 AM
The connection to the non-bridging terminal is open/broken.
mike49504 27th May 2010 05:43 AM
I dont see any boken traces on the board at all. So since the right channel is number 2 do i trace the positive terminal ?? Since the left positive and right negative are for bridging
Perry Babin 27th May 2010 07:29 AM
Yes. You can move the speaker wire from the non-bridging terminal of the dead channel to the non-bridging terminal for the other channel to see if the channel will produce audio.
Copyright 1999-2017 diyAudio
