Im working on this amp it had power supply and output problems. I replaced the NDP6060's in it with NDP7060's I also replaced the outputs in the amp and emitter resistors.
Amps power light will not light up but its producing rail voltage I have bot + -30volts on the outputs. This is the voltages i get from the SG3524N DO theese appear to be right or do i have a problem still 1:0 2:2.54 3:0.18 4:0 5:0 6:3.46 7:2.17 8:0 9:4.32 10:0 11:6.92 12:18.86 13:18.85 14:6.93 15:18.85 16:5.08 Power supply Fets 1:6.50 2:13.89 3:0 |
#2 |
It looks OK. If you move the power supply rail switch to the other position, does the LED light up?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
No cant get it to light at all
#4 |
Is that the only problem (does the amp produce clean audio)?
#5 |
Amp has DC voltage on left channel and right channel is dead
#6 |
Do you have clean audio an the point where R30/32 connect together?
Do you have clean audio an the point where R33/34 connect together? You shouldn't have more than a few millivolts of DC on either of these.
#7 |
Where r30-32 meet no signal
R33 and 34 meet no signal 0 volts across the emitters |
#8 |
Try moving the airbass switch to the other position and check for signal again. You may need to work it and the other switches back and forth to clean their contacts.
#9 |
tryed moving the switch about 100 times back and fourth along with the others still no signal.
#10 |
Drive a strong audio signal into the amp and post the op-amp outputs that have signal. You only need to check the output pins of the op-amps.
| SoundStream Rubicon 1002 Turn-On Delay | kds9591 | Car Audio | 11 | 26th March 2012 11:47 PM |
| Soundstream Rubicon 502 Repair Problem | Blazemore | Car Audio | 24 | 29th January 2010 08:18 PM |
| Soundstream Rubicon 204 amp. need help ! | minde16v | Car Audio | 3 | 23rd November 2009 07:38 PM |
| Soundstream Rubicon 702 Issue | Lobby Ludd | Car Audio | 4 | 24th September 2008 06:21 PM |
| Soundstream Rubicon 805 | audiobahnkid592 | Car Audio | 16 | 23rd July 2008 10:13 PM |
| Page generated in 0.09865 seconds (73.74% PHP - 26.26% MySQL) with 11 queries |
