Go Back   Home > Forums > General Interest > Car Audio
Old 28th May 2010, 02:48 AM   #11
NE5532AN the following pins have signal on them
2
3
5
6
NE5532AN
1
2
3
5
6
7
Old 28th May 2010, 02:58 AM   #12
Post the IC number (U1, U2, U3...) and the output pins of each one with signal on them.
Old 28th May 2010, 03:45 AM   #13
U2
PINS 2,3,5,6 have signal on them Pins 2,6 the signal is clipped
U1 pins 2,3,5,6 have signal on them
Both op-amps have + - 17 volts on them and the rest of the pins are at 0
Old 28th May 2010, 02:17 PM   #14
Perry,
I played around again with one of the switches and i now have signal where r30-32 meet and r33-34 meet
One of the driver boards is getting warm.
Also a tip 102 and 107 in the power supply section are getting warm also at idle maybe the regulators?
Old 28th May 2010, 11:15 PM   #15
Q43 and 50 are the regulators.
Do you have audio on the formerly dead channel?
Old 29th May 2010, 12:05 AM   #16
The one channel is still dead and the other has Dc on it
Old 29th May 2010, 01:16 AM   #17
For the dead channel, do you have audio on at least one solder pad for the driver board?
Old 6th June 2010, 01:04 AM   #18
Back to this amp again I found a bad op amp and replaced it I of the outputs has 20 volts of Dc on it. I checked the outputs none read shorted but wondering if they are leaking hers what i came up with.
Tip 107
1-2:8.21 reverse probes 1-2:OL
1-3:8.84 reverse probes 1-3:8.84
2-3:OL reverse probes 2-3:1.444
TIP 107
1-2:8.23 reverse 1-2:OL
1-3:8.80 reverse 1-2:8.85
2-3OL reverse 2-3:7.91
Tip 107
1-2:29.41 reverse 1-2 OL
1-3:9.65 reverse 1-2:8.71
2-3:OL reverse 2-3:7.73
TIP 107
1-2:1.516 reverse 1-2:OL
1-3:8.04 reverse 1-2:8.73
2-3:OL reverse 2-3:7.61
Tip102
1-2:OL reverse 1-2:6.00
1-3:8.04 Reverse 1-3:8.06
2-3:6.08 reverse 2-3:OL
Tip102
1-2:OL reverse 1-2:5.98
1-3:11.81 reverse 1-3:11.84
2-3:6.03 reverse 2-3:11.87
Tip 102
1-2:Ol reverse 1-2:7.13
1-3:5.49 reverse 1-3:5.51
2-3:7.13 reverse 1-3 OL
Tip 102
1-2:OL reverse 6.83
1-3:5.21 reverse 1-3 5.21
2-3:6.84 reverse 2-3:OL
Hope you can make out all this Do any appear to be leaking/BAD?
Old 6th June 2010, 01:26 AM   #19
You can't determine if they're leaking unless they're out of the circuit.
Old 6th June 2010, 01:29 AM   #20
They are all out of the amp I tested them 3 times out of the amp and thats what i came up with. All the readings i posted were taken with them out of the amp Thats why i was asking the readings look strange to me
SoundStream Rubicon 1002 Turn-On Delay kds9591 Car Audio 11 26th March 2012 11:47 PM
Soundstream Rubicon 502 Repair Problem Blazemore Car Audio 24 29th January 2010 08:18 PM
Soundstream Rubicon 204 amp. need help ! minde16v Car Audio 3 23rd November 2009 07:38 PM
Soundstream Rubicon 702 Issue Lobby Ludd Car Audio 4 24th September 2008 06:21 PM
Soundstream Rubicon 805 audiobahnkid592 Car Audio 16 23rd July 2008 10:13 PM
Copyright ©1999-2013 diyAudio
