i got this xtant amp to fix its pushin and pulling the speakers in so i know its a shorted out put any info on this amp would be helpful thanks
#2 |
whats a good replacement for SSP45N20
#3 |
N20A or N20B?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
N20a.
#5 |
I've never found any good subs for them except for amps with rail voltage lower than ±70v. For those, I use the IRF3415. I've tried some of the NOS SSP45N20As with mixed results (mostly bad).
#6 |
i was going to change them all because its pushing and pulling the subs but this amp is weird so im trying not to blow it up.but that would be the cause of that right?
#7 |
Is it going into protect?
How far is it pushing the speaker? Does it produce any audio?
#8 |
no the amp stays on and plays music but it will slowly suck the speaker in and out
#9 |
That's probably not the outputs. What are you using for a signal source?
#10 |
it was doing this in the car the person had it in he didnt know what he was doing i haven't played it i just checked everything since the person was already in it. but he had three amps on a crappy ground,and on one cross over that was not set. would that cause it?
| Help with Xtant x603 | shawnk | Car Audio | 50 | 15th February 2010 05:03 AM |
| help with my Xtant 1001d | 91h22a | Car Audio | 18 | 7th August 2009 08:49 PM |
| xtant x604 | mike49504 | Car Audio | 3 | 13th January 2009 05:23 PM |
| Xtant X1001 | shagone | Car Audio | 11 | 15th April 2008 12:28 AM |
| xtant 3300c | nath339 | Car Audio | 4 | 30th March 2008 02:50 AM |
| Page generated in 0.08742 seconds (76.98% PHP - 23.02% MySQL) with 10 queries |
