Planet Audio ZR300.4
Old 24th May 2010, 01:50 AM   #21
Perry Babin is offline Perry Babin  United States
It sounds like it may have an intermittently shorted power transformer.
Old 24th May 2010, 01:57 AM   #22
o. l. t. is offline o. l. t.  United States
Seeing as it has stopped working again, I feel you may be right.
Old 24th May 2010, 02:17 AM   #23
With all power semiconductors clamped tightly to the sink and a 10 amp fuse in the B+ line, power the amp up and twist/push/pull on the transformer to see if it blows the fuse. If you have a current limiter (headlamp or large 2 ohm resistor), that would be better than the fuse. You'd have to monitor the voltage across the resistor with a meter to see if there are any changes in current draw.
Old 24th May 2010, 03:09 AM   #24
At the moment it won't even power up and it is getting 5v out the chip as it should so it's the +12 side that is not working properly I'd say. I dunno, about to chunk it out the window and forget it. Not worth it.
It works then don't, then works, then don't. Now nothing at all.
Old 24th May 2010, 03:11 AM   #25
Post the voltage on all of the pins on the 494.
Old 24th May 2010, 04:46 AM   #26
Actually you can hear the transformer make a tiny "tink" sound when you connect the remote. It's trying, but nothing is flowing. I think I have a bad capacitor.
Planet Audio ZR300.4Hide this!Advertise here!
Planet Audio VX2200D tdetlor Class D 0 4th February 2010 02:58 AM
Planet Audio Vortex AMP I.D. ?? Scanlines Car Audio 4 15th May 2009 08:47 PM
Need specs for Toshiba, Planet Audio SharpyWarpy Multi-Way 0 21st April 2007 07:00 AM
Planet Audio amp rader Car Audio 3 7th November 2006 09:50 PM
Current Planet Audio Amps 69CamaroSS396 Car Audio 1 30th July 2006 04:29 PM
