Got this amp in for repair the power supply is blown.
They are using SMP6N06's with 10 ohm gate resistors. Can i sub the Fets in this to something else? |
#2 |
Using a sub shouldn't be a problem. What FETs do you have?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Irfz44's
Irf3205's FQp65n06's Is all i have right now til the rest of my order comes in a few days |
#4 |
Assuming that you meant that it's using 60No6s...
If it's using the same drive circuit as the orion amp that's very similar, it can drive either the 65N06 or the 3205 and both are rated for more current.
#5 |
Perry,
I also found the following resistors toasted wondering if you might know the values. |
#6 |
#7 |
Cool i would greatly appericate it. My email is mike49504@hotmail.com
#8 |
sending as we speak
#9 |
Perry,
I have this pic of a hot setup which is the same as the one im working on. I must be going blind i cant make out the the 4th color band on the resistors circled. Wondering what ohms theese resistors are? |
#10 |
They are all likely 10 ohms. The two on the end of the board are probably connected between the collector of the PNP drivers and ground. The other one is a base/gate resistor and would be the same as the other base/gate resistors for the other power supply transistors.
| Bridge LM1875 HS | JhonDoe | Chip Amps | 17 | 30th July 2010 01:15 PM |
| Hs anyone tried these......> | DIYIdaho | Full Range | 7 | 13th December 2009 04:43 AM |
| F2 running hot(how hot is hot?) | Aron | Pass Labs | 10 | 13th February 2009 03:42 PM |
| Orion NT 200 vs Orion 2150 SX | Clipped | Car Audio | 3 | 12th June 2007 01:55 PM |
| Nice HS for GC | Praudio | Swap Meet | 1 | 17th September 2003 12:40 PM |
| Page generated in 0.11113 seconds (76.72% PHP - 23.28% MySQL) with 11 queries |
