Does anyone have a part number for the 1k resistor between D199 and D198 diodes.I just spent 2 hours searching mouser and my brain is fried.Any help would be appreciated,thanks.
Perry thank you for the info on the diode. |
#2 |
660-RK73H3ATTE1001F should be the same diode.
Don't reinstall R198 (striped end directly connected to RCA jacks). If the amp loses ground with that diode in the circuit, it will burn the RCAs or the RCA shield on the head unit.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Thanks Perry.So just leave that diode out?
The resistor reads 970 ohms should i replace that or is that close enough. |
#4 |
Leave the diode out. They were not installed on later versions.
That's close enough but if you have to order parts, you should order and replace the resistor.
#5 |
Thank you Perry.
#6 |
Perry,I got it all put back together installed in truck.The left side rca input is not working.I can put the L rca cable in the R input and i have sound.But if I try the R or L rca cable in the L input on the amp,no sound.So it's some thing in the amp.
Would you have any suggestions on what to look for?The sound is super loud so I'm kind of confused.Thanks Perry. |
#7 |
Can you move the RCA connector around when it's plugged into the left jack to make the audio play through?
If not, you'd need to follow the signal from the RCA jack through the circuit to see where it's lost. There isn't much between the two points.
#8 |
I wiggled it around and didnt get anything.I'll trace it down and see where it goes.I appreciate the help Perry.
#9 |
Perry the input has a tiny resistor,board designation R102,am I right in assuming that it is 20k ohms?I could be wrong my dmm has been acting funny.
#10 |
I don't have a good photo of that area on the 1501 but on the 81000 (which is very similar), it's a 2k resistor (marked 2001). It's inside the frame of the RCA jack marked J148.
| MTX Thunder 1501D | spooney | Car Audio | 49 | 16th July 2010 04:55 AM |
| Repairing MTX 1501d - Help a newb | scoob8000 | Class D | 4 | 22nd January 2009 11:31 AM |
| mtx 1501d sawtooth waveform | Speeed3 | Car Audio | 53 | 1st July 2008 08:28 PM |
| mtx 1501d | ONEGGT | Car Audio | 0 | 18th October 2007 08:07 AM |
| Page generated in 0.10009 seconds (75.85% PHP - 24.15% MySQL) with 10 queries |
