I now it's a long shot, I thought I would check. Thanks a bunch!
#2 |
Are you sure it's a 100HD?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Yes sir! Old school for sure. It's the 4ch version of the 30hd.
#4 |
Generally, the only practical way to repair those it to replace the modules. All of the ones I've seen had too many problems to repair the modules. The ebay seller dealsbyjason may have the modules but he doesn't list them often. You have to contact him through ebay to see if he has them.
#5 |
I have purchased boards from him before. Maybe I'll check with him. I'm really bumm'n since I bought this amp "new" and found that all of the 10uf caps on the smd board were leaking and one channel had ~10v across it's leads. I replaced all of the caps, two op amps, and three channels worked great. After the fix, the bad channel had ~6v ac and would produce static through a speaker. Then I shorted something (rookie mistake!!) as I didn't realize I still had power applied to the amp and now all outputs appear to have full rail voltage ~20v. Thanks for the input Perry. I'm not sure what I should do at this point. I can't even reference the fets in this amp: R8939 & R8943 (outputs) R8944 (power supply) 8932 (voltage regulator ??). I might be s.o.l. here..lol
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| rockford fosgate power 650 mosfet | mike49504 | Car Audio | 43 | 24th March 2011 10:21 PM |
| rockford fosgate power 300 mosfet | mike49504 | Car Audio | 26 | 23rd December 2009 04:06 AM |
| Rockford Fosgate Power 800.4 | lostamps | Car Audio | 6 | 2nd January 2008 12:21 PM |
| Page generated in 0.06431 seconds (77.30% PHP - 22.70% MySQL) with 10 queries |
