Go Back   Home > Forums > General Interest > Car Audio
Old 6th May 2010, 02:12 PM   #1
Default Bazooka EL1500
Im working on this amp also. When i power it up the light comes on for a few secs and shuts off.
I tested the output for DC and have 0.68 volts on the output with no Outputs in the amp.
I have -14.68 volts on the op-amps but no + voltage on them.
On the rectifiers this is what i have
U1620
1:-1.48
2:-1.52
3:-1.35
U1620R
1:-.068
2:-71.4
3:-0.69
Old 6th May 2010, 02:52 PM   #2
What DC voltage do you have on the RCA shield?
Black probe on the amplifier's ground terminal.
Old 6th May 2010, 02:59 PM   #3
On the rca shield when first powerd up it has 1.23 volts then drops to 0.23 volts
Old 6th May 2010, 03:37 PM   #4
Measure the resistance between the RCA shield, the secondary center tap and the negative speaker terminal. Do you read 0 ohms between all of those?
Old 6th May 2010, 03:56 PM   #5
yes from rca shield to negative terminal 0.2 ohms and from secondary center tap to rca shield 0 ohms
Old 6th May 2010, 04:02 PM   #6
Measure the DC voltage on the rectifiers again but place the black probe on the negative speaker terminal.
Old 6th May 2010, 04:09 PM   #7
U1620
1:-1.45
2:-1.52
3:-1.42
u1620r
1:-0.70
2:-71.4
3:-0.71
Old 6th May 2010, 04:14 PM   #8
If you measure from the outer legs of the positive rectifier to the outer legs of the negative rectifier, do you read 0 ohms?
Place the probe on the legs as close to the body of the rectifier as possible.
Old 6th May 2010, 04:50 PM   #9
U1620 to U1620R
Leg 1-1:0l Reverse probes : 5.92 ohms
Leg 3-3:Ol reverse probes OL
Old 6th May 2010, 05:02 PM   #10
I think you have broken solder connections or broken legs on the positive rectifier.
frequency response for bazooka sub deriver23 Car Audio 1 24th August 2006 12:44 AM
bazooka csw1204 MyNameIsJake Car Audio 1 24th December 2005 06:08 AM
what type of enclosure is bazooka? fossilfool Subwoofers 8 28th November 2005 04:43 PM
Page generated in 0.10024 seconds (76.20% PHP - 23.80% MySQL) with 10 queries
