800a2 Power Supply Heating up
Old 5th May 2010, 06:48 AM   #1
Brain Fried is offline Brain Fried  United States
Brain Fried's Avatar
Question 800a2 Power Supply Heating up
I just got another 800a2 in for repair when you power it up the transform starts squealing and starts heating up and four of the fets heat up as well Q12,Q13,Q14,Q15 They were replaced with IRF3205 the other side Q5,Q6,Q7,Q8 are MPT75N05HD they are staying cool the amp is drawing 3 1/2 amps at idle with the Bias turned all the way down there no shorted outputs the amp plays all the resistors are good.Perry you have any idea what it could be?
Old 5th May 2010, 08:28 AM   #2
Perry Babin is offline Perry Babin  United States
Did you check or replace the gate resistors and the driver transistors?
Old 5th May 2010, 03:12 PM   #3
The gate resistors are 68ohms for the IRF3205 and the same the the MPT75N05HD.I pulled the center legs on al lfour of the IRF3205 on the amp now it idles at 1.26amps
Old 5th May 2010, 03:38 PM   #4
midnightg35x is offline midnightg35x  United States
I would make sure that both sides of the PS use the same FET. I know Perry a lot of times also suggests going down to a smaller resistor (22 ohm?) when using the IRF3205 assuming the drive circuit can handle the extra current.
Old 5th May 2010, 03:41 PM   #5
68 ohms may be a bit high for the 3205s. I'd suggest using 47 ohm resistors.
Measure the DC voltage on the gate leg of each of the power supply FETs (FETs out of the circuit as you have them now). What do you read on gate legs?
Old 5th May 2010, 05:23 PM   #6
Gate voltage Q15 5.50V, Q14 5.50V, Q13 5.50V, Q12 5.50V, Q5 5.49V, Q6 5.49V Q7 5.49V Q85.49V
Old 5th May 2010, 05:49 PM   #7
Those look OK. The problem is likely the gate resistors.
Old 5th May 2010, 06:00 PM   #8
so change the gate resistors from 68ohms to 47ohms ?
Old 5th May 2010, 06:03 PM   #9
That would be my suggestion.
You could also try measuring the DC voltage across each of the 0.1 ohm resistors in that channel to confirm that every one has exactly 0.000v DC across it.
Old 5th May 2010, 06:19 PM   #10
with all the power fets center legs disconnect i am getting 262.5mv on the irf9640 and 118.9mv and going up on the irf640 at the 0.1 ohm resistors
800a2 Power Supply Heating upHide this!Advertise here!
Rockford fosgate 800a2 fongman Car Audio 40 9th September 2014 11:18 AM
Rockford Fosgate 800a2 mike49504 Car Audio 12 28th April 2010 11:01 PM
rockford fosgate 800a2 mike49504 Car Audio 11 4th February 2010 08:34 PM
New member 800a2 ? Life is an Enigma Car Audio 11 6th March 2009 12:32 AM
rockford 800a2 fried channel help . ethridgeruby Solid State 1 22nd July 2005 08:02 AM
