Go Back   Home > Forums > General Interest > Car Audio
Old 29th April 2010, 10:50 PM   #1
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Default I was experimenting with punch 60.2
I bought this amp blown on eBay for 8 dollars and well I had three sets of IRF3205s fets and I slapped them in w/o checking the drive circuit and gate resistors and after i finished putting them in the amp powered up fine buy I noticed the drive transistors got a tad bit warm??? Is it because this is a higher powered MOSFET? Or should I lower gate resistor value? And to what ohm? I really didn't think this amp was going to work because it was fried pretty bad but it powered and played music fine but it was a 3 min test.Would this be fine with those transistors? Or no.
Feel the PUNCH
Old 29th April 2010, 11:29 PM   #2
Where did you install 3 pairs of 3205s in a 60.2?
For 3205s, 47 ohm resistors are typically used. if the ones in that amp are greater than 51 ohms, I'd suggest replacing them with 47 ohm resistors.
With no B+ power applied (only remote and ground), measure the DC voltage on leg 1 of each of the power supply transistors. Place the black meter probe on the amplifier's ground terminal. Place the red meter probe on the point where you need to measure the voltage. What do you read?
Old 30th April 2010, 04:46 AM   #3
Amp works and so I'm assuming the drive circuit also works because the amp turns on and plays music but I need to change the gate resistors so the drive transistors can swith pwr supply mosfets on faster. Okay so this amp has been repaired before because the outputs are irf530 and irf9630. Usualy the outs are irf540 and so on. But it plays music fine?? Should I change the outputs to originals?
Feel the PUNCH
Old 30th April 2010, 09:05 AM   #4
The fact that it produces clean audio doesn't mean the drive circuit is working properly (although it probably is).
To get a better idea of the condition of the drive circuit (assuming that you don't have a scope), measure the DC voltage on the gate leg of each of the power supply FETs. Do they have the same voltage?
If you're going to sell the amp or if you have to order other parts, you should replace the outputs. If it's your own personal amp and you don't need any other parts, it's really up to you whether you change them or not. When you install it, use a 25 amp fuse so the power supply will be protected if the outputs fail.
Yamaha M-60 power amp for sale (w/ impaired C-60 preamp) rainzoneman Swap Meet 10 3rd December 2009 01:44 PM
Worth repairing a Rockford Fosgate Punch 60.2? wpc Car Audio 14 1st July 2009 06:25 PM
punch 60 dsm getting warm ben04srt Car Audio 5 3rd June 2009 10:37 PM
Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY ppia600 Swap Meet 0 23rd February 2008 01:17 AM
My experience: the cheap punch set VS Greenlee punch vax9000 Tubes / Valves 5 21st July 2006 07:52 PM
Page generated in 0.08292 seconds (74.37% PHP - 25.63% MySQL) with 10 queries
