| View Poll Results: Kenwood or Power Akustic Mono block | |||
| Kenwood |
0 | 0% |
| Monoblock |
1 | 100.00% |
| Voters: 1. You may not vote on this poll | |||
Ok I had a kenwood KAC-9104D amp. Spilled redbull and it got under my seat and fried it.. Anyways I was going to go kenwood till I found out they dont cover warranty on items from ebay.. Nevertheless I ran across an auction for Power Akustic LFA1-5500D (A.K.A Loud Fukin Amp)
Are these any good? how so compared to a name like kenwood? I am disabled and far from rich, but music is the only thing left keeping me young (26 and feel like i am 80) Specs:
#2 |
Numbers are a bit exaggerated. 14.4Vdc * 200A = 2880Watts. Sure you could peak over this number without blowing fuses, but you couldn't sustain that power without shutting it down.
The only power acoustic amp I have used BAMF series and the supply dropped as you loaded it. You couldn't get twice the power by halving the resistance, supply wasn't strong enough. I only assume this amp would act the same. |
#3 |
thanx for the quick response. So you think the kenwood series are better? I put my kac-927 in temporarly and suprisingly its turning more heads then the mono did.. Weird how old stuff gives off that grab your chest feel.
#4 |
what about some other brands?
#5 |
well basically got a kenwood that I want to fix, but dont wanna envest 30 in chips and mosfets for something else to be wrong. So pretty much looking for affordable yet quality mono.. presenting 2 polk 12" db series so roughly 400w rms each for now, With definate plans to get higher watt subs later.. Suprisingly them polks take everything that kenwood can toss out
| Kole KX1-5500D in protect mode. Shorted diode? | barros57 | Class D | 2 | 13th February 2010 01:41 PM |
| TA8259H Max Power 37W BTLx4CH audio power IC for sale | winkison | Swap Meet | 0 | 10th July 2008 09:42 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| High Freq. AC Power for Filaments of 300B SE Power Amp? | snoopyma | Tubes / Valves | 6 | 3rd January 2004 06:21 PM |
| Page generated in 0.10445 seconds (77.54% PHP - 22.46% MySQL) with 11 queries |
