Perry This question for you i just pick up a fosgate 801s its been repaired **** poor job by the way and they replaced the IRF640 with IRFB31N0D when i look them up it said they are for power supply
but the amp is playing no distortion should i replace them with the right ones? or will these work well in place of the IRF640?
#2 |
If you have an oscilloscope, look at the waveform on the speaker terminals. If the waveform is displayed as a sharp clean line (not a fuzzy looking line, as it would be if there was low level oscillation) and the amp produces clean audio rail to rail without going into protection, they are probably OK. If there is any oscillation or it's going into protect mode, for an unknown reason, replace them. It's almost always best to use the exact replacement part but if they're in there and they're working perfectly, there's really no reason to replace them.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 | |
#4 |
Replace the mismatched 0.1 ohm resistors also. They need to be matched as closely as possible. THESE are the ones I'd recommend you use.
Since the 0.1 ohm source resistors opened previously, check all of the 100 ohm and 39 ohm resistors connected to the source resistors. You'll need to remove the source resistors (or at least desolder one leg) to get accurate readings.
#5 | |
after this one i will have 20 left.
#6 |
#7 |
In many of the large Rockford amps, it's extremely important that you replace the driver transistors when the outputs fail. If one is leaky (something that's difficult to detect while the transistor is in the circuit), it will blow the outputs as soon as the mute delay ends. The outputs aren't biased on until the end of the delay and with the huge bank of capacitors, there's no way for the fuse to blow or a current limiter to protect the amp. It simply blows the outputs.
#8 |
| Need help with Rockford Fosgate 801s | robsmetalcraft | Solid State | 3 | 27th February 2010 09:28 PM |
| Rockford Fosgate 801s | mike49504 | Car Audio | 11 | 17th February 2010 11:47 PM |
| FosGate 400a4 | Gusel9 | Car Audio | 0 | 16th June 2009 04:30 PM |
| Fosgate PR250 | Leo_Smith | Car Audio | 10 | 10th June 2008 04:36 AM |
| Fosgate outputs | clayton | Car Audio | 2 | 23rd July 2004 02:14 AM |
| Page generated in 0.11519 seconds (74.31% PHP - 25.69% MySQL) with 10 queries |
