Hi guys,
i have an orl orion hcca250 completely dead. Cosmetically in great condition, no missing parts or blown parts. But it does not switch on, seems to have supply issues. I only noticed the transistor near the lm7815 is quite warm, does it mean anything? Thanks a lot in advance! |
#2 |
Can you post a photo of the board so we can see which one you have?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
#4 |
I don't know which board it has by looking at the outside. There was some overlap between board revisions and the various models.
#5 |
Fine, just wait some hours and you'll get the pic...;-)
#6 |
#7 |
#8 |
With your multimeter set to DC volts and the black meter probe on the shield of the RCA jacks, what is the DC voltage on the transistors connected to the large green resistors?
You don't have to post the voltage for each one. You simply need to determine if they have approximately 25v (both positive and negative) on their legs.
#9 |
Thanks Perry,
so I have to check the voltage on the transistors, fine. I'm not at home now, so I will check on friday, and let you know the results...
#10 |
ok guys, here we go...
I'm checking the tl494, switching controller. Pin 12 has 9V supply, and on pins 8 and 9 i see something like 20kHz switching frequency, is it possible?(i checked with the multimeter, don't have oscilloscope here). So the tl494 drives the mpsa06 and mpsa56 and they drive the power mosfets(smp60n06). Probably one of the two is burned? ![]() I didn't have removed any of the power mosfets for now, but between drain and gate i see(checking the diode with multimeter) 250mV both sides... Maybe someone is broken? |
| Dead Dead Laser Pickups - why not replacing the Diode only? | Salar | Digital Source | 9 | 24th January 2010 01:44 PM |
| Orion #5 | Clipped | Car Audio | 1 | 21st November 2008 04:34 AM |
| Modifying a 2150GX into a HCCA250 | mitchyz250f | Car Audio | 9 | 11th March 2008 12:51 PM |
| Orion NT 200 vs Orion 2150 SX | Clipped | Car Audio | 3 | 12th June 2007 01:55 PM |
| Need Orion HCCA250 pictures | shallowfu | Car Audio | 14 | 21st April 2007 06:27 AM |
| Page generated in 0.10161 seconds (77.42% PHP - 22.58% MySQL) with 10 queries |
