Im Rebuilding The Power Supply In This Amp. The Rectifiers Are Shorted In It Also. Wondering What A Good Sub Is For Theese?? This Is What's In It Now.
The Numbers I Have Are Off The Board And Rectifier Itself. C25 40 02C F12C20C C25 53 02N F12C20A |
#2 |
The MUR1620CT and MUR1620CTR should be good subs.
Have you pulled them and confirmed that they're shorted. It's rare that more than one rectifier shorts.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
1 Of Them Is Shorted. The Other Rectifiers IN The Amp Have Broken Legs On Them And Have A Ton Of Solder On Them Looks Like Someone Tryed To Solder The Legs Back Together And Did A Hack Job. So Im Gonna Just Replace Them All.
Perry, The Next Question Is The Owner Of This Amp Told Me He opened It UP And He Said That The Amp Was Repaired Wrong From A different Shop. He Said That The Resistors Are All Falling Out of The Amp. I Told Him That was How It Came From THe Factory . He Insist's I Resolder All Of Them . Wondering How I Can Tell Him That It Wont Effect The Amp IMHO. Or Should I Resolder The Entire Board?? Heres Some Pics Of What Im Talking About Its Prety Much 3/4 of The resistors On The board Very Time Consuming |
#4 |
If he wants to pay you an hourly rate (whatever it's worth to you), do it. If he doesn't, explain that you can't work for hours on something that has no affect on the proper operation of the amp.
#5 |
Perry,
Do you by chance know the value of theese resistors? |
#6 |
Probably 8.2k ohms. On other crunch amps, it's printed on the board under the resistor.
#7 |
Its says 4K7 on the board 4K or 47K ?
#8 |
The K is used in place of the decimal point. It's a 4.7k ohm resistor.
#9 |
Thanks Perry,
1 Last question. some of the outputs are shorted 2SC5200's Will the 2SC5200-0's work? |
#10 |
I would think so since all links to the -0 part led me to the non-0 datasheet. The FJL4215 and FJL4315 will be easier to find. Mouser has them.
http://www.fairchildsemi.com/ds/FJ/FJL4315.pdf
| Crunch amp | mike49504 | Car Audio | 6 | 22nd January 2010 06:49 AM |
| Crunch USA amp | Kronan | Car Audio | 0 | 11th November 2006 08:08 AM |
| The crunch | meanman64 | Car Audio | 3 | 6th March 2006 04:18 AM |
| Crunch Amps. | Radik | Multi-Way | 0 | 13th March 2004 01:29 AM |
| Page generated in 0.10704 seconds (74.72% PHP - 25.28% MySQL) with 11 queries |
