Go Back   Home > Forums > General Interest > Car Audio
Old 24th April 2010, 09:18 PM   #1
Default Lighting audio S2.300
Got this amp in for repair. The guy said he blew 2 subs off this amp.I checked it out and found 2 shorted outputs. I replaced the shorted outputs and moved all pots/switches around several times. But the channel that was blown still has an issue with new outputs in it the channel distorts like crazy.
I checked all op-amps and have + - 15 volts on them all other pins 0 volts.
It looks like they are using the 5 watt ceramic resistors for the emitters
Wondering what else i should check since the left channel distort's like crazy
Old 25th April 2010, 12:28 AM   #2
With a speaker connected, post a photo of the distorted waveform.
Old 25th April 2010, 03:20 AM   #3
I figured it out. It was some bad solder connections
jl audio 300/4 repair brianfulcher15 Car Audio 3 16th June 2009 05:45 AM
Help to repair JL audio 300/2 Solosound Car Audio 42 20th March 2009 12:52 AM
JL Audio 300/4 PQatPIT Car Audio 5 4th March 2009 02:06 PM
jl audio 300 2 ppia600 Car Audio 2 6th April 2008 03:54 PM
buyout lighting audio P3.12.4's -- who got 'em? mista2 Car Audio 2 4th November 2004 06:42 AM
Page generated in 0.06505 seconds (70.25% PHP - 29.75% MySQL) with 10 queries
