I have an old Advent PA250 amplifier here. A couple of the power supply fets were open and a couple of the gate resistors were charred but somehow it still appeared to work ok. Anyways its clearly not right so I'd like to change the fets and gate resistors without spending any more money than I have to. I have IRF3205 and RFP70N06 on hand as well as 22 ohm and 100 ohm gate resistors. Will any combination of these work to replace the original IRFZ34N's with 100 ohm gate resistors. If anything I'd rather just buy resistors if need be
#2 |
From what I can see on the ampguts photos, it appears that they're using a PNP pulldown transistor so you should be able to use either of those FETs with the 22 ohm resistors.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| Hitachi FET Substitution | poor_lackey | Solid State | 20 | 12th March 2011 01:15 AM |
| Orion HCCA amp parts substitution question | ECM | Car Audio | 33 | 5th January 2008 10:55 AM |
| chipamp.com kit - part substitution question | speakerguy79 | Chip Amps | 2 | 22nd November 2007 05:59 PM |
| Dynaco ST70 clone, tubes substitution question | bembel | Tubes / Valves | 5 | 13th October 2006 02:03 PM |
| Yikes!! FET Substitution? Could use some FET Guru's here... | EchoWars | Solid State | 15 | 9th February 2004 07:08 PM |
| Page generated in 0.07306 seconds (70.46% PHP - 29.54% MySQL) with 10 queries |
