Go Back   Home > Forums > General Interest > Car Audio
Old 23rd April 2010, 04:19 AM   #1
Default Boss American amp
The outputs in this amp are BUZ21's The outputs are shorted wondering if theres a good sub for theese?
Also This amp looks like it was made by ZED AUDIO it has alot of Resistor packs that say ZED AUDIO on them. Did zed make amps for BOSS??
Old 23rd April 2010, 04:27 AM   #2
If you don't want to use the original replacement part, the IRF540 would probably work.
Old 23rd April 2010, 04:33 AM   #3
Ok thanks Perry,
I also have another BOSS amp that came in today for repair Its using tip 35's and 36's They seem to test fine But im getting 1.51 volts of dc on the outputs.
Wondering what might cause this a leaking output? Or something else?
Old 23rd April 2010, 05:15 AM   #4
If it's not drawing excess current, I'd suspect one of the (4?) transistors that make up the differential amplifiers for that channel.
A leaking output would probably cause excessive current as the servo tried to correct for the offset.
Old 23rd April 2010, 07:01 PM   #5
jol50 is offline jol50  United States
Likely can search this site for it, iirc Boss and Pyle made or sold US made amps back in the day. Thinking Zed did make them much like PPI made them for many. Most say on the board or say made in USA.
Old 24th April 2010, 01:01 AM   #6
spooney is offline spooney  United States
zed did make a few boss amps. post a pic of the board. would be a tell tale sign
Old 24th April 2010, 03:49 AM   #7
ppia600 is offline ppia600  United States
Yeah, they did. And so many people bought them for CHEAP and don't realize how good they are. I installed several that people bought at a local pawn shop new for dirt cheap. After installing the first and noticing the mosfet outputs through the clear cover I realized by the board components and design they weren't made by boss. Then after hearing them it confirmed my suspicion. What were they thinking, lol? Boss must have paid big to get them made to boost their reputation.
Don't worry... you can always turn the gain down!
Old 12th May 2010, 04:05 PM   #8
Back to this amp again The power supply fets are also blown. They are using BUZ102's with 100 ohm gate resistors.
Will 44's,3205's, 46's or ndp7060 work as a sub?
Old 12th May 2010, 04:09 PM   #9
The 44s should be a good sub.
Old 12th May 2010, 04:12 PM   #10
Ok Thanks Perry,
I dont have to swap the gate resistors do i?
boss amp question mike49504 Car Audio 3 11th September 2008 02:40 AM
Fixing a BOSS REV3000D amp KyferEz Class D 46 5th June 2007 05:35 AM
BOSS Amp soundNERD Car Audio 3 17th August 2004 12:06 AM
Boss REV3000D blown amp. Repair Suggestions? KyferEz Car Audio 4 5th May 2004 11:30 PM
Fixing my Boss car amp (Split) immeraufdemhund Solid State 2 8th January 2003 08:39 PM
Page generated in 0.10017 seconds (78.14% PHP - 21.86% MySQL) with 10 queries
