OK my son came to me last week and ask me to build him a car audio amp so i told him i will try to do my best. I have a good idea but i am not sure on some of the parts on the schematic i have a clear idea i know some of them are capacitors but i want to be 100% sure here a picture of the schematic the areas highlighted in yellow are the parts i am not sure what they are. I will appreciate any help you guys give to help complete this for my son.
#2 |
Those are capacitors but if you haven't purchased the IC yet, you may want to use something like the 3886 which requires fewer external components.
LM3886 - High-Performance 68W Audio Power Amplifier with Mute You could also try posting this on the chip-amp forum if you want other suggestions.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 | |
so those are capacitors so i was on the right track my next Q is there are two that are marked 33p & 47p what are they?
#4 |
33 and 47 picofarad would be my guess.
What are you going to power it with?
#5 |
#6 |
Yeah... I think it will be enough.
#7 |
#8 |
It still has a lot of external parts.
I don't mind trying to help you with this but the guys in the chip-amp forum have a lot of experience and can provide more reliable information. Tell them what you want from the amp and that you have a power supply that produces ~±60v (which can be modified to produce slightly more or less voltage). They may be able to tell you the best chip to use that has a minimum of external parts. When you build this, you will probably have engine noise. You may have to use a ground loop isolator to get rid of it.
#9 |
Perry got a quick question on the 800a2 power supply. I know the rockford power supply is 50v +/- and for what i and doing i need 60V +/- so i am thinking of the power mosfets from the MTP75N05HD to NTP75N06 Tell me what you think here is the datasheets for both of them.
MTP75N05HD pdf, MTP75N05HD description, MTP75N05HD datasheets, MTP75N05HD view ::: ALLDATASHEET ::: http://www.datasheetcatalog.org/data...NTP75N06-D.PDF |
#10 |
Those don't affect the rail voltage.
Have you measured the rail voltage? I think it's likely to be closer to ±58v.
| Custom Home Theater Project in New Home, Opinions appreciated. | thadman | Multi-Way | 5 | 20th November 2008 12:40 AM |
| Home Theater Sub Project | Focus | Subwoofers | 9 | 21st April 2006 07:30 PM |
| First home DIY project - need guidance | Lusso5 | Multi-Way | 9 | 19th December 2003 12:28 PM |
| First home speaker project, need measurements. | HiggityHank | Multi-Way | 7 | 4th December 2003 02:18 PM |
| Page generated in 0.10215 seconds (75.95% PHP - 24.05% MySQL) with 10 queries |
