I recieved this amp in for repair. on legs 1 to 2 of the power supply fets is reading shorted. And also across Power and ground is reading shorted.
so i pulled the power supply fets,rectifiers,power supply driver board,and the large diode and the drivers for the power supply fets. Still reading shorted across power and ground terminals. Wondering what could cause this?? |
#2 |
Do any of the components you pulled read as shorted?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Power supply fets read shorted.
#4 |
It's unlikely that anything left on the board is shorted. Clean the board thoroughly to remove all of the flux and examine the entire power supply area to see if there are any solder bridges.
#5 |
Since i took the rectifiers out and it still reads shorted the problem is in the power supply or could it still be in the output section?
#6 |
It's almost certainly in the power supply area. The most likely areas to be shorted are around the power/ground terminals or on the FET pads.
#7 |
Ok cleaned the board off in the power supply section now it doesnt read shorted Thanks Perry.
The orginal fets are IRFZ44A's will the 44n's work? |
#8 |
I can't find a datasheet on the Z44A but I'd expect the Z44N to work properly.
| Aura Evolution VA100 • Clean up & upgrade | Malefoda | Solid State | 85 | 13th May 2012 08:14 PM |
| Aura CDP • Clean up & upgrade | Malefoda | Digital Source | 39 | 5th April 2009 09:40 AM |
| 18" Aura MR18.4 subwoofer | nwpadmax | Swap Meet | 0 | 2nd April 2008 07:02 PM |
| FS: Aura Linaeum tweets & MR15.4, diyma12 | kappa546 | Swap Meet | 5 | 7th July 2007 08:22 AM |
| Aura NSF8 (flat 8" woofers) in doors? | SHEEPDOG1973 | Car Audio | 1 | 8th June 2007 06:56 AM |
| Page generated in 0.07835 seconds (79.95% PHP - 20.05% MySQL) with 10 queries |
