Go Back   Home > Forums > General Interest > Car Audio
Old 9th April 2010, 05:33 AM   #1
Default Building a Cyclone subwoofer? Rotary servo sub?
Hi everyone,
I'm new here, as you can probably see. I'm interested in building a PG Cyclone-esque subwoofer using a servo motor (or two?).
Would I need some kind of return mechanism so that the vane won't drift forward or backward? Will I need any kind of special wiring, or will the AC current from my amp be enough to produce the kind of back-and-forth rotation I need?
Last but not least, what brand/size/kind of rotational servo motor should I use, and should I use one on each end of the spiral vane to reduce the effort each has to put in?
Any help is greatly appreciated.
Old 9th April 2010, 05:41 AM   #2
PG Cyclone[non cone subdriver]
Old 9th April 2010, 04:44 PM   #3
spooney is offline spooney  United States
I think you are venturing into uncharted territory as far as building diy cyclone subs . I wish you luck though and look forward to the results.
Old 9th April 2010, 06:48 PM   #4
I just goggled about 12 page of projects concerning rotary sub-woofers and the Thigpen designs including a tear down and rebuild of the cyclone from PG.
PG still sells a rebuild for that product. I would contact then on the Rodin site for support.
The DIY has a bunch of posts about it. Have you tried a search of this site yet ? Hope this is helpful some...
Major Issues With Building The BPA200 Reference Servo Circuit! MartyM Chip Amps 9 8th March 2008 10:50 PM
Subwoofer Servo Chris Rudden Subwoofers 11 8th December 2006 11:26 PM
Rotary Servo Sub Enclosure (Cyclone) mbcouple Subwoofers 1 23rd May 2006 09:12 AM
Servo rotary subwoofer! Audiophilenoob Subwoofers 17 6th October 2005 12:37 AM
Page generated in 0.07408 seconds (72.34% PHP - 27.66% MySQL) with 10 queries
