anybody ever seen/heard of putting two 6.5" speakers in a box (seperated internally by a wall) but in the same box? I'm interested in finding/building a box with twin 6.5" speakers in it...
#2 |
Speakerholic
sure, nothing wrong with that. You don't even have to divide it, just make it twice as big as for one woofer.
#3 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Actually nowadays it is a very common arrangement. A side benefit (Amongst others) is locating a 'tweeter' between the woofers.
This arrangement "corrects" what's called lobing errors. Kinda like my DIY speakers...two 6 1/2 " drivers, and a tweeter between the two. __________________________________________________ _____Rick..... |
#4 |
I have seen 4 x 6.5" in each box
#5 | |
#6 | |
Thank you very much for your time, I know that my question are probably simple ones to you. |
#7 |
I think he's referring to what's called an isobaric arrangement. There are several ways to use 2 drivers together in a box, it would help if you gave us an idea of the use you're going to make of the cabinet. Vas is a speaker parameter, used (with others) to determine the size of box required.
Do you have particular drivers already?
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky Last edited by PeteMcK; 18th May 2010 at 04:45 AM. |
#8 |
It may be not for sure so simple...Just thinking of the variety of speakers produced ,it is not even easy for a 6,5" to do Isobaric
Which ,isobaric ,has often been used in the cars..and is often referred to a narrow band of low frequencies reproduced (by the isobaric sub) and has the plus of allowing one membrane to "see" the other ,reducing some distortion related to weight and velocity . If large air pressures (low and loud frequencies)can be calculated and also the box , it may be not so predictable for mid-tones...since one cone's movement will be determined by the other ,and big oscillations and not exact matching would produce some cancellation in the mid-range , well ![]() maybe is the isobaric that prevails ![]() I'm looking for a "filler" to cover the hole in that range....anybody
| Fender "Twin Reverb Amp" has no output. | Pioneer621 | Tubes / Valves | 8 | 21st January 2009 05:20 PM |
| DIY "speaker box" ("BOOM BOX"). Help needed. | MASantos | Full Range | 6 | 2nd September 2007 12:00 PM |
| replacing 12" sub in box with back speaker mounted 6" subs | aussiebuddha | Car Audio | 7 | 14th October 2006 08:26 PM |
| Twin volt drivers in sealed box enclosures | jez | Multi-Way | 5 | 21st March 2005 01:48 PM |
| How Do You Build A 12" Speaker Box | jamesrb2004 | Subwoofers | 3 | 15th February 2004 06:17 AM |
| Page generated in 0.10862 seconds (80.37% PHP - 19.63% MySQL) with 11 queries |
