| Home | Forums | Rules | Articles | Store | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving |
Thread Tools | Search this Thread |
#1 |
diyAudio Member
would adding capcitance to the board on these amps produce more output? It has two small caps on there with room for two more. I looked at other rf amps and they have the same #of fets jus more capicitance. Does anyone known what size caps they are and/or if these "Mundorf M-Lytic Audio Grade Power Capacitors" in the 63v/2200uF size would work. sry if this is a repost, i tried to post this type of info.question yet it didnt show up on the forum.
#2 |
diyAudio Member
Adding the capacitors will be a waste of time and money.
__________________
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
diyAudio Member
Thanks, so just as an aside what do those caps do? These amps are birthed @200+ watts yet cea rated at 75? i ve looked at other rf amps and the p 400-2 has only 4 fets yet more capacitance and is cea rated at 100? Does the fet count need increase due to the T-series amps handling lower impedances?
#4 |
diyAudio Member
Isn't it only the class D amps that handle lower impedances?
The caps store energy and then supply current between power supply pulses. In car amps with switching power supplies, the time between pulses is almost non-existent so you don't need significant capacitance like you would for an amp being powered by 50-60Hz sine wave.
__________________
#5 |
diyAudio Member
All the amps from the power series are 1 ohm stable. I get the idea of needing the power when the low notes hit. So my next question is.... how can you tell how much power an amp should put out? That thing has 8 mosfets for gosh sakes?lol. The p400-2 i have has 4 yet it is rated at a higher wattage cea?yet has only 4 fets?
Sorry for asking so many questions but My birth sheet was a like 1174 on a 2 mohm mono load. I have alot of amps and maybe they are just beasts or that was a ** sheet not a birth sheet,lol. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rockford T5002 | Bobdabuilder | Car Audio | 0 | 7th April 2010 11:48 PM |
| ROCKFORD a SERIES | mjh7096 | Car Audio | 4 | 17th January 2010 05:40 AM |
| Rockford T20001BD. Need help | Chris87 | Car Audio | 4 | 15th November 2009 09:47 PM |
| Rockford T20001bd | PQatPIT | Car Audio | 4 | 11th January 2009 06:59 PM |
| Help me with Rockford 500bd | valterdaw | Car Audio | 7 | 19th May 2007 08:43 PM |
| New To Site? | Need Help? |
| Page generated in 0.07702 seconds (70.72% PHP - 29.28% MySQL) with 10 queries |
