diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Rockford T5002 (http://www.diyaudio.com/forums/car-audio/164703-rockford-t5002.html)
Bobdabuilder 7th April 2010 11:48 PM
Rockford T5002
These power elite amps aare said to be beatsly and have by no means not performed to there CEA rating. I wonder though if the birth sheet numbers are possible? They supposedly average @225 rms to a 4 ohm load. Correct me if i am wrong but they should put out above the 75 watts vea based on their output stage? 8 mosfets? I have really been studying amplifier layouts, and i can only assume that since they have as many fets as say a p5002 then power output @4 ohms should be close. The major diff I see between amps is capcitance and the t5002 has little(opinion). I was wondering if someone could verify or falsify my theory that if i where to add two caps to the amps power stage it might be a stronger amp. I really want more power to my mids and midbass's. my mids are on one @2 ohms, midbasses another @4 ohms.
Copyright 1999-2017 diyAudio
