Go Back   Home > Forums > General Interest > Car Audio
Old 7th April 2010, 09:31 PM   #1
Default Are there two PCB versions of the Kicker KX1200.1?
I have a blown kicker kx1200.1. One side of the PS FET's were blown, along with its associated driver and channel on the TL494. After looking through a couple of the threads on here, it appears I have a different version of the PCB. For starters, it appears that other people have the gate driver transistors for the power supply being labelled as Q05 and Q11. In the other threads they seem like they are SOT-23 parts using the MMBTA56 as a substitute part. On my board, it looks like Q10 and Q16 are the drivers and they are TO-92 PNP transistors. I cannot find Q05 or Q11 anywhere near the TL494 chip. Has anyone else ran into this? Are these the only gate drivers or are there another two for a push-pull configuration? I do not see any other TO-92 parts.
Also looking to find a substitute for the drivers I did find. The parts are labelled:
Q10:
K232
A1266
GR
Q16:
K044
A1266
GR
It looks like the original part was a KEC KTA1266GR. Does this sound correct? Fairchild lists the KSA1015GR as a direct replacement. Are there any other replacements or upgrades I could use?
Lastly, everyone seems to have IRF3205's as the PS FET's with 47ohm gate resistors. The one I have had IRF3205's with 22ohm gate resistors. I realize this probably helps drive the IRF3205's harder, but is it normal? I am not sure if I should look for upgraded current handling in my driver transistors.
Old 7th April 2010, 10:39 PM   #2
There are 2 versions. The red board used 100 ohm resistors. The green board used 22 ohm resistors.
The gate resistor value depends on several things. In an amp without additional dead time programmed into the drive circuit, the 47 ohm resistors are generally a good value. With additional deadtime, the 100 ohm resistors can be used. The 22 ohm resistors will work with the 3205s as well.
The 1266 was the original part.
The 1015 seems to be essentially identical. It should be a good substitute.
Old 7th April 2010, 10:50 PM   #3
poopydoopynoopy's Avatar
Send a message via Yahoo to poopydoopynoopy
been running 1015's in mine a week now no issues...(JBL green board)
Old 8th April 2010, 12:42 AM   #4
OK thanks guys. I had blown PS FET's, drivers, and one channel of the TL494. I do not have any subs for the drivers right now, but after I replaced the TL494, I got my clean square waves back. Each pulse was ~20uS with ~3uS of deadtime between pulses. Keep in mind this was without the drivers or PS FET's. I think my deadtime is sufficient. I am going to be replacing the PS FET's with IRFB3306 using 22 Ohm gate resistors.
To verify, there is only one PNP gate driver transistor per side, correct?
Old 8th April 2010, 12:45 AM   #5
Those are going to be more difficult to drive than the originals. Why not simply use the original part number?
Old 8th April 2010, 04:52 AM   #6
It is because it is what I have on hand. I used these on a previous amp with no issues as a substitute. Actually, as I look at the specs, it looks like the IRFB3306PBF is easier to drive than the IRF3205PBF. What specs in particular lead you to believe that the 3306 is harder to drive than the 3205? Maybe I'm missing something.
Old 8th April 2010, 04:58 AM   #7
Input capacitance.
Old 8th April 2010, 05:14 AM   #8
OK, I see that. Isn't gate charge a better indicator of how hard a transistor needs to be driven? I seem to remember having talked to an app engineer at IRF about this once before about a year ago when I was working on a circuit for my job. He pointed me to their following app note: http://www.irf.com/technical-info/appnotes/an-944.pdf
In there, this is what I took out of it (quoted on page 5):
As this application note shows, of “bottom line” importance is the total gate charge required for switching. The lower the charge, the lower is the gate drive current needed to achieve a given switching time.
I hope you don't think I'm trying to be difficult, I'm just trying to learn
Old 8th April 2010, 05:30 AM   #9
I could be wrong but in all instances that I've encountered for 'power supply FETs', the Ciss seemed to coincide with the amount of drive current required to properly switch the FETs on/off.
I constantly have people trying to modify or improve circuits designed by professionals. Many times, it leads to a lot of time troubleshooting and, in the end, they end up using the correct part. People, many times, wrongly assume that they have improved a circuit in some way but they lack the ability or desire to properly test the circuits under all possible operating conditions so they don't 'really' know if the circuit is performing better (or even operating properly). They simply feel good because they believe they are better/more intelligent than the people who make a living doing design work.
I've seen too many instances where simply changing an op-amp (something too many people want to do) caused problems that weren't immediately obvious. Using substitute parts in class D output stages causes even more problems.
I've found it best to use the proper parts, as long as they're still available.
Old 8th April 2010, 01:48 PM   #10
Fair enough. Thanks for the insight. I'll report back here if I encounter any other issues with this amp. Thanks!
Need a little help fixing a kx1200.1 Pics Inside wccoug21 Car Audio 10 5th October 2011 03:32 PM
New versions badman Wild Burro Audio 2 26th March 2010 09:45 PM
Kicker KX1200.1 went up in smoke phil33875 Car Audio 10 25th March 2010 01:37 AM
Kicker KX1200.1 Class D blown mbates14 Car Audio 9 5th February 2010 04:00 AM
Mini-a Versions sandstorm33 Pass Labs 16 4th May 2008 08:25 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
