Go Back   Home > Forums > General Interest > Car Audio
Old 7th April 2010, 09:05 AM   #1
amc32 is offline amc32  United States
Default Mod advice needed for noise
This inquiry isnt related to another thread that I have began. I have a class D massive amp that has what seems to be excessive floor noise. That is still present when gain controls are high or low. I have verified that the ground sheild of the rca's and power supply transformer secondary center tap is common. With a resistance of 220 ohms.
My question is there a mod that I may add internally to the amp to help reduce this noise?
Iam using a jcv head unit on my test bench as my reference not an ipod and an regulated powersupply (pyramid 50amps max. with voltage and current meters)
...............I Hear in color.................
Old 7th April 2010, 04:16 PM   #2
Noise isn't typically a problem with these amps (clone used by power acoustik and many others). Does the noise decrease when you switch from master to slave?
Can you hear the noise through a woofer?
Does the output at the speaker terminals have a lot (more than a volt) of high frequency noise with a load connected?
Old 8th April 2010, 02:47 AM   #3
dc off-set at speaker terminals is 1.8volts. There is no master slave switch. This a 3000.1 model. Dc offset remains the same regardless of gain and/or sub-sonic controls. But when installed in car it has more floor than usual. When I short rca shield to transformer tap the noise is greatly reduced but still a little bit there.
Any suggestions?
Old 8th April 2010, 03:23 AM   #4
It doesn't need modification, it needs to be repaired.
Precisely what model Massive is it?
Philips CD 720 mod advice needed... mickie Digital Source 1 27th November 2007 06:00 PM
Speeding up my Digital (mod advice needed) BobM Digital Source 1 18th September 2004 12:54 AM
HELP! High gain, low noise fet advice needed! Lenin Swap Meet 17 21st February 2002 12:08 PM
Help! High gain, low noise fet advice needed! Lenin Solid State 1 16th February 2002 01:53 AM
Page generated in 0.07710 seconds (64.57% PHP - 35.43% MySQL) with 10 queries
