Go Back   Home > Forums > General Interest > Car Audio
Old 5th April 2010, 10:51 AM   #1
Default bias current on rockford punch 200.4
Hello
i repair a punch amp 200.4 (4x25wrms)
the guy who have this amp before burn the mosfet in the supply and he modify the bias current
i find information to set the correct bias current here
Rockford Corporation Technical Library CD
but I do not know which way to turn the potentiometer to set it to the minimum before turn on the amp and procede to the bias set
is it in clockwise or counterclockwise ?
and what are the resistors to set the bias because i must put my multimeter on it to mesure 4 or 5 millivolt on each (rockford say that in the service manual)
I surrounded the resistors if you can confirm me if it is good please ?
I think the amp was build in 2000
Thanks for your help
Old 5th April 2010, 01:38 PM   #2
Turn them counter clockwise. I watch the idle current of the amp using a .005 ohm resistor in series with the amp B+ terminal. If you turn the pot slowly the idle current will increase quickly, then I back it off. You can find the knee at which the current takes off. I usually set it there and let it warm up and verify current doesn't increase.
Old 5th April 2010, 05:06 PM   #3
Hello
Thanks brandes.cm
Yes the current increase quickly i move a little and the current increase...
i use a 12 volts supply with 5 Amp to set up the bias current i set up to 4.5mv on the 0.1ohms resistor and now the amp works fine and without heat
I mesure before adjust the bias and i have for channel front Left 17.5mv and 2mv for channel front right
for the rear channel i have 3mv and 18 mv
the guy who have this amp before me make nonsense
Now i run the amp in my car and works better
The bias was verry difficult to set 30 minutes to do because I am a perfectionist
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Rockford Punch 75 (non HD) Clipped Car Audio 8 18th October 2007 10:56 AM
rockford punch 60ix transistor please ferreyrafede Car Audio 10 21st February 2007 08:37 AM
Rockford Fosgate Punch sub question audiomachines Subwoofers 4 18th August 2006 01:51 AM
Rockford Punch 250x2 gti311 Car Audio 6 14th October 2005 07:26 PM
Page generated in 0.08636 seconds (76.67% PHP - 23.33% MySQL) with 10 queries
