Go Back   Home > Forums > General Interest > Car Audio
Old 5th April 2010, 12:36 AM   #1
Default Diamond 1000 amp
I forget the exact model, its still at the shop. But all the outputs, power transistors are shorted. the outputs are FRP40N10 which i cannot find anywhere. Anyone have a substitute?
it also has an HIP4080 driver.
Old 5th April 2010, 01:05 AM   #2
In all of the 4080 based amps that I've tried them in, the IRF3710Z (<< Z is important) has been a good sub.
Old 5th April 2010, 03:47 AM   #3
ok. when i did the 40N10 over at newark, they substituded it with a IRF1310NPBF. I was just making sure and double confirm before i went and blown any money on that FET in case it wasnt right.
Old 5th April 2010, 03:53 AM   #4
I've tried 1310s and they wouldn't work. Your amp may be different. I can't guarantee that the 3710Z will work but I've had good luck with them.
Old 5th April 2010, 03:54 AM   #5
ok. Well i will stick with your suggestion anyway.... you havent failed me yet. hehe.
Also someone added 10k gate resistors to all the fets thinking it was going to fix the problem. I am sure 10K isnt the right gate resistors.
Diamond Amp TimS Solid State 9 19th January 2009 01:20 AM
Diamond Hex DA 5.6 - Eton &amp; LPG Drivers omarmipi Swap Meet 3 1st March 2006 04:28 PM
Page generated in 0.07642 seconds (71.36% PHP - 28.64% MySQL) with 10 queries
