Hello
I have bought an old amplifier Blaupunkt GTA 400 for 20 euros ![]() i change 4 mosfet to the SMPS supply because 1 was burnt.... the sound of this amp is verry bad, so i keep only the smps to build my own amplifier ![]() but i need to change other components because i can here a zzzz when the amp is power on without music I think the noise is due to the rust on the resistance ![]() the resistor is a 22 ohms and it comes verry hot when the supply works i don't know why ? can someone can explain me that please ?I surrounded the rust on the resistor ![]() This is the power supply with other condensators i use 2 condensators of 10000µF low ESR for the secondary 2 condensators of 2200µF for the primary and 1 condensator of 1000µF near the terminals to replace the old condensator ![]() I search the schematic of this amp, if someone have it can you give me please ? Thanks in advance hervé
#2 |
#3 |
Can you post a photo of the bottom of the board?
Photograph it at a slight angle so that there isn't any glare from the flash.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
Hallo European neighbour!
I have schematics for serveral GTA amps, but not exactly for this one. If you could post a pic from the solderside, it would really help, perhaps one of mine will be (nearly) the same! |
#5 |
hello
![]() Thanks for your answer this is a photo ![]() a photo where are solder the resistor who are verry hot 75 °C The C is condensators with a value of 0.1µF "i think " on the condensator i can see 0.1 J 63 so i think 0.1µF 63 V ?![]() and i would like to know how can i do to have a +/-12 volts to power a preamp please? |
#6 |
The snubber resistors will run hot but they may be running hotter than normal due to the two missing caps. From what I can see in the photos, there is one 2200uf on each side of the inductor. That leaves only one on the transformer's primary. That could cause more ringing on the primary which could cause the snubber resistors to run hotter.
The simplest option for the regulated preamp supply would be to use 7812 and 7912 regulators (if you want 12v instead of 15v). The caps are 0.1uF@63 ±5%. Have you confirmed that they're not shorted?
#7 |
Thanks Perry
![]() i will put the 2 missing condensators, but they are hot before i remove the 2 condensators so is it normal that resistors are hot ? and why? Can you explain me what is the function of theses resistors please ? for the capacitor i think there are ok i change them but i haven't tools to test them.... the preamp is this product the aop are NE-5532 but i can change them and i put OPA2134PA from burr brown ![]() Préamplification - Module Préamplificateur Buffer Stéréo AOP NE-5532 it works with a +/-15 V but i don't know the consump in A ![]() Thanks for your help
#8 |
The missing caps were getting hot?
The snubbers (RC network) are used to damp ringing on the transformer. Under normal operating conditions, they will operate at slightly elevated temperatures. 75C is hotter than normal but, in some amps, they run that hot. The 5532 is a perfectly good op-amp. There's no reason to change it. Current consumption of most op-amps used for preamp audio have negligible current draw unless you have a large number of them.
#9 |
the missing caps are not hot but they are old i'll change them with the same 2200µF because they are in // on the circuit
I change the NE 5532 because the sound was not clear with it but now with the burr brown it's better ![]() This supply power up 4 channel amplifier do you think i can use it with 2 module like that ? PSC-Audio | Module PsC-Audio | FET100 - 100W @ 4Ohm; 65W @ 8Ohm ± 45V; 0,1%THD the maximum current consump is 3 A by amp the manual in *.pdf http://www.psc-audio.ro/catalog/html...T100_print.pdf Thanks
#10 |
If the audio wasn't clean from the 5532, it was defective or there was a problem with its power supply or the circuit it was in. No one can hear the distortion produced by a 5532 in a properly designed circuit. For those who want to argue this point, you'll have to go elsewhere. I won't be dragged into a senseless discussion. Douglas Self published distortion curves showing that it produced less than 0.001% THD + noise, even when loaded to 500 ohms (tough load for an op-amp).
What is the rail voltage produced by this power supply? If it's more than 35v, you'll have to do something to drop the voltage before it's fed into the 7815/7915 regulators. I wouldn't use this supply for much more than ~200 watts if you're going to drive the amps hard for long periods of time.
| Search for the Sugden A21 schematic | danka | Solid State | 1 | 20th February 2012 09:55 PM |
| Search 35T Schematic | olaychang | Tubes / Valves | 0 | 7th November 2008 10:50 AM |
| Setting up Blaupunkt GTA-250 | Simpleton | Car Audio | 0 | 20th July 2005 10:33 AM |
| KT 88 schematic search | andrewe1 | Tubes / Valves | 6 | 14th April 2005 07:33 PM |
| in search of a schematic | vlljpior | Tubes / Valves | 0 | 28th February 2005 11:46 PM |
| Page generated in 0.12208 seconds (82.71% PHP - 17.29% MySQL) with 10 queries |
