Go Back   Home > Forums > General Interest > Car Audio
Old 31st March 2010, 08:15 PM   #1
Default 6V amp mod
I have a 1960 VW Bug that is still on a 6VDC system. I want to be able to have some tunes! Basically what i want to do is modify the amp to run on 6VDC with a 12VDC output to run a head unit off of. I know that this can be done, but i dont want to spend 350 bucks to have someone else do it for me. I just dont know where to start.
Old 31st March 2010, 09:51 PM   #2
What amp do you have?
Old 31st March 2010, 10:33 PM   #3
You need a boost converter. These take many forms. The smartest way would, I think, be to build a converter with some germanium power transistors or modern FETs. Another approach would be a second 6V battery that you put in series with your car battery, and charge it when not in use.
A third, perhaps more sophisticated method would be to use two 6V amplifiers with a phase inverter driving one, and connect your load between the outputs, bridge style it's called. I used this system to get more than 20 Watts from an 8wpc stereo amplifier.
Old 1st April 2010, 09:53 AM   #4
dangus is offline dangus  Canada
J.C. Whitney used to sell 6V to 12V converters. Hit a few car parts swap meets (the season starts about now) and you may pick one up for a few bucks. You need 12V for the head unit anyway.
How about converting the car to 12V? I'm fairly sure you're not the first person to do it, so there's probably complete instructions out there somewhere. It would make for a much more practical car to drive, not to mention easier starts, brighter headlamps, etc.
Old 1st April 2010, 06:13 PM   #5
Yes, I could convert to 12v, but the car has been 6v for the last 50 years so i want to keep it that way, there are fewer and fewer 6v bugs running around these days. There is a guy on thedsamba.com that sells an amp that has been converted/modified to accept 6v input and has a 12v output to run the amp. I am sure that he has built a converter circuit inside the amps housing, and that is where he is getting the power to run both the amp and the head unit. The problem is he is charging 350 for the amp. I have several amps laying around the house, I am fairly knowledgable with a soldering iron, and i believe that i have the skills nessacery to modify one of my amps.
The problem with the converters that i have seen is they only put out one amp if not less, not really enough to run a radio, let alone an amp on. I am not wanting to get a booming bass system, just enough to run some 6X9's.
Old 1st April 2010, 06:15 PM   #6
TheSamba.com :: VW Classifieds - 6 Volt Power Amplifier 600 Watt 4Ch
This is what i am trying to replicate. I do not wish to convert to 12v as the car was built with 6v, and everything else is still original.
Old 1st April 2010, 06:18 PM   #7
Post a list of the possible candidates (amps you have) for modification.
Old 1st April 2010, 06:23 PM   #8
firechief's Avatar
Post the models of both the amp and head. This all depends on how much power you will be consuming, then we can start.
Old 2nd April 2010, 03:01 AM   #9
Bob_345 is offline Bob_345  United States
ok buy a 12v battery and isolate the stereo circut from the rest of the cars electronics, buy a 12v alternator , dont replace the 6v one and you are good. dependin on the space around the engine, 2 alternator should work. its been done before and with great succsess
Old 2nd April 2010, 03:31 PM   #10
poopydoopynoopy's Avatar
Send a message via Yahoo to poopydoopynoopy
Convert that car to 12v.
6V Vibrator Refurbish? 65blkbkgt Car Audio 3 6th February 2009 03:19 AM
6v 5AR4? pftrvlr Tubes / Valves 7 9th February 2008 01:32 AM
12v to (6v times 2) legendaryfrog Parts 8 27th October 2006 09:34 PM
Plitron 30VA, 6-0-6V transformer orthoefer Swap Meet 0 4th September 2006 09:34 PM
how do you convert 9V to 3.6V Gizmotech Parts 6 27th March 2005 05:51 PM
Page generated in 0.10364 seconds (77.52% PHP - 22.48% MySQL) with 11 queries
