What Amp/s do i need?
Old 28th March 2010, 07:25 AM   #1
Ateball is offline Ateball  Australia
Ateball's Avatar
Default What Amp/s do i need?
Hey guys, I'm in need of some advice as to what Amp or Amps that would be necessary to run my new sub woofers.
I have two 12" Solobaric-L7 Kicker subs.
Max Watts=1500 watts
RMS=750 watts
I was just wondering what you guys would recommend i am at a loss.
Cheers
Old 28th March 2010, 05:55 PM   #2
spooney is offline spooney  United States
Are the subs dual 4 ohm or dual 2 ohm? If they are dual 4 ohm you want something that will do its highest rated power at 1 ohm and if you have dual 2 ohm subs you should find an amp that does its highest rated power at 2 ohm. I would try to find an amp that does approximately 1500 watts rms give or take a couple hundred watts. There are many choices. What brands are available in your country?
Old 29th March 2010, 10:34 AM   #3
Ateball's Avatar
Yeah, in aussie, there are a few good car audio shops around the place.
Some of the brands that i can recall of the top of my head are:
Boston
Clarion
Fusion
JBL
JL AUDIO
JVC
Kenwood
Kicker
Alpine
Pioneer
SONY
Soundstream
But most brands are readily available by order/over the internet.
I'm looking at getting the dual 4 OHM subs.
Old 29th March 2010, 08:46 PM   #4
jol50 is offline jol50  United States
Select them according to your budget, then review what you have left.
What Amp/s do i need?Hide this!Advertise here!
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 04:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 10:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 11:28 AM
Copyright ©1999-2017 diyAudio
