the remote screw is stripped in the terminal block and im in need of a new one any body know were i can get one?
#2 |
Is the screw stripped or is the block stripped?
If it's the block, you can probably tap it to the next size or possibly get one from JBL (probably not worth the time/effort/expense). If you're going to tap it, don't use a thread tap. It will take out too much material and leave a sloppy fit.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
the idiot previous owner used a cordless impact screw driver meant for 8 inch long decking screws, and it snapped the head of the screw right off and spread the hole out enough to crack the plastic that surrounds the terminals. i tried to drill it with my snap on bits then with my dremel but thats some hard metal and barley put a dent in it.
#4 |
You'd probably need a carbide burr to cut that screw. Sometimes, you can go through the wire port to cut the screw in half. That reduces the tension and allows you to unscrew what's left of it.
| JBL Speaker Parts | ARRAY | Swap Meet | 2 | 25th March 2010 01:51 PM |
| WTB: RGR Model IV parts or parts unit | dnewma04 | Swap Meet | 2 | 1st January 2010 09:00 PM |
| WTB: JBL 2262H drivers | mobyd | Swap Meet | 0 | 26th June 2009 09:15 PM |
| WTB: JBL L128h woofer | Tronhead | Swap Meet | 1 | 17th October 2008 03:00 PM |
| Wtb Jbl 2226 | corkster | Swap Meet | 2 | 1st February 2008 11:24 AM |
| Page generated in 0.08639 seconds (70.07% PHP - 29.93% MySQL) with 10 queries |
