Sony XM-1004gx
Ok got 3 out of 4 channels working. Front right channel is dead.
I have both + - regulated voltages on all op amps on the cross over board. I tryed all switches and pots.
I checked for signal on outputs its saying i have ouput on the speakers terminals for both channels but right channel is dead when a speaker is connected
Any ideas?
Ok i have audio signal on the crossover boards on all op-amps pins 1 and 7
Its showing i have audio signal on both positive and negative terminals of the right channel.
But right channel does no produce sound even know with the scope its saying i have signal on both positive and negative terminals on that channel.
Left front channel plays fine shows signal on the positive terminal and deflects on the negative terminal.
But the right shows signal on both positive and negative
