I have a PPI PC2400 that has some blown power supply FETs. Somebody has tried to repair this previously (and poorly) and it has a mix and match of IRF44N's and NTE 2395's. Which one is the OEM FET? If it is the IRFZ44N, I plan to replace them with the IRFB3806 because I have used these as substitutes before and I have an almost full tube of them left. Also, is 47ohm correct for the gate resistor? Both the IRFZ44N's and NTE 2395's have 47ohm resistors that look original, but I can't be 100% on that. Thanks
#2 |
IRFB3806 are good for this application.
http://www.irf.com/product-info/data...rfs3806pbf.pdf very very low gate capacitance device. 47ohm it's ok. check the colour for gate resistor, so we're sure for 47ohm
#3 | |
![]() Thanks |
#4 |
great
you can use IRFBs without problem
| PPI PC2300.2 power supply issues | durwood | Car Audio | 13 | 26th February 2010 04:56 PM |
| ppi x3 power supply transistors... what are they??? | ppia600 | Car Audio | 8 | 28th March 2008 03:18 PM |
| PPI PC2400 technical questions.. | MatthewS | Car Audio | 6 | 26th February 2008 05:10 AM |
| PPI PC2150 (c.1997/8) Power Supply Noise | 17Peaks | Car Audio | 7 | 19th September 2006 03:32 AM |
| Problem identifying power supply FET | R33_Cam | Solid State | 3 | 26th July 2004 09:22 AM |
| Page generated in 0.07913 seconds (73.34% PHP - 26.66% MySQL) with 10 queries |
