Punch 150 schematic needed
The bass will play but there won't be any bass boost.
See attached for the resistor connections.
i don't know of any drop in replacements (if someone else does, please post a link to the source) but a friend found the ones shown in the attached photo on ebay. The spacing between sections wasn't correct but the minor modification (wire leads) made them usable.
Wow that is amazing! I do have some resistors of that value I guess ill just use this method for getting the amp to play. I just got to say these things are built really good and the solder connections to each component it's much different compared to a more modern printed circuit board. Everything else seems fine just the pots are gone. Thanks for the help!
