need help
need help
Old 18th March 2010, 12:18 AM   #1
the fox is offline the fox  Canada
Default need help
Hello i have a 06 Dodge Durango and i got a new double din and i want to install it but want to know if i can hook up my factory roomount dvd player to it. All I really want is just the audio to play through the door speakers because my headphones for the unit stoped working. I dont want it only to play the dvd through my new head unit i want the kids to be able to put the dvd in the back and just watch it. thanks for any info.
Old 18th March 2010, 07:17 PM   #2
brandes.cm is offline brandes.cm  United States
If the deck would have a cd changer output that could be converted to an input, you could then run your audio into the deck that way.
Old 18th March 2010, 07:23 PM   #3
Glowbug is offline Glowbug  United States
Glowbug's Avatar
It should just have an aux. line level input that you can switch to - you might have to buy a cable if it's an Alpine or something with a proprietary plug, but it wouldn't be too much trouble.
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 18th March 2010, 11:42 PM   #4
thanks for your replys but where would i get the power from because isn't the roofmount dvd player powered from the factory deck? and my new deck doesnt have the same plug the the factory one does not and the aftermarket harness has nothing to plug the dvd plaeyer. thanks again
Old 19th March 2010, 12:31 PM   #5
What model is your aftermarket deck? Alpine, Kenwood, JVC and a host of others have cd changer ports that convert into Aux in for your audio. And most of the newer decks already have an input on the rear or front.
The power may be just a simple remote turn on wire like an amp, not sure. Contact a dealer, they might supply you with a wiring diagram for it.
need helpHide this!Advertise here!
