Rockford Fosgate Punch 150 HD
Does anyone know where i can find the replacement plug for this amp for power and ground? Also the speaker plug the connects to the one in the pic?
Buy or modify to fix A old Punch etc...
Hello:Mike.
You may check on Ebay or seaches looking for buy one. Or you can remove power block & solder power wires black 4 or 8 ga direct to main CBA .It alway work for old school Amp units in my shop. Then you do a same O/P PLUG for smal Ga wires.:)
Hope this Help Mike from Tech Henryv
found this on the rockford site
Punch 150 (ser. 3) Speaker Harness (amp side) Molex 050-84-1060 Digikey WM1248-ND
Punch 150 (ser. 3) Pins for Speaker Harness (amp side) Molex 02-08-1004 Digikey WM1271-ND
Punch 150 (ser. 3) Speaker Harness (speaker side) Molex 050-84-2060 Digikey WM1249-ND
Punch 150 (ser. 3) Pins for Spekaer Harness (speaker side) Molex 02-08-2004 Digikey WM1270-ND
Punch 150 (ser. 3) Twist Lock Fuse Holder Littelfuse 155120U Mouser 576-01550120ZXU
Punch 150 (ser. 3) 6A Fuse Littelfuse AGA6 Fuses Unlimited AGA6
Punch 75 HD Speaker Harness Molex 39-01-2060 Digikey WM3702-ND
Punch 75 HD Pins for Speaker Harness Molex 39-00-0078 Digikey 39-00-0078-ND
