Rockford Fosgate 1500bd
I dont understand this amp.
If i have no outputs in the amp it powers up and idle's fine.
I replaced the output that i thought might have been bad.
If i reinstall the outputs amp draws 60+ amps of current.
Outputs check fine resistors check fine the mic4420's test fine.
Wondering what else it could be?
Perry,
I got this figured out so now with the outputs back in the amp it idles fine.
I checked the Lm6171's and the A2211's I have + - 9.78 on all of them.
i checked the power supply pins and toched everything on the board voltage stays the same.
Anything else i should check before i check the output again and have it blow up in my face once again??
Im not sure. Ive repaired atleast 80 fosgate amps with thoose mesha boards and have never had a problem with any of them.
The guy told me he had it at another shop before me and theyve been in business 25+ years . He said they told him it couldnt be fixed .
Well with your help ive proved them wrong but after alot of time and my own money.
Only problem is i have 2 more of the same amp on my bench for repair also. But i know theese amps very well now.I will probably get to thoose in the next couple weeks first i have to get caught up on other repairs
