Hifonics BXI608 repair
Old 18th March 2010, 02:34 AM   #11
greg_gorrell is offline greg_gorrell  United States
Yes, they are all blown, I'm guessing the gate resistors are blown also, so I'm gonna order those.
Old 18th March 2010, 02:41 AM   #12
Perry Babin is offline Perry Babin  United States
It's rare for more than 1 output to fail on each side but even if that's the case, you'll have to replace all of them because they're in parallel groups.
Before you order parts, you should check the drive signal for the FETs. Do you have a scope yet?
Can you post a photo of the inside of the amp?
Old 22nd March 2010, 02:17 AM   #13
I do have access to a scope, and will check the signal tomorrow. I just took a pic of the guts and Ill post it following this.
Old 22nd March 2010, 02:53 AM   #14
Old 24th March 2010, 07:14 PM   #15
I havent gotten a chance to check the signal yet Perry, as I have pulled a few of the FETs out. Is there any way of checking the FETs for a short or open with them in the circuit?
Old 24th March 2010, 07:52 PM   #16
Checking them in the circuit isn't definitive unless they're shorted or leaking badly. If they're in parallel with FETs that failed, they'll have to be replaced.
Old 31st March 2010, 10:44 PM   #17
which are the drivers for this amp?
Old 31st March 2010, 10:58 PM   #18
Can you re-post the photo of the inside of the amp (or email it to me babin_perry@yahoo.com)?
Old 1st April 2010, 02:12 PM   #19
If I'm not mistaken, the transistors in the yellow rectangle are the drivers. Check the signal on the first leg of each driver transistor. The right (falling) edge of the drive waveform should be perfectly vertical down to within ~1v of ground. Compare it to the waveform on pins 9 and 10 of the TL494/TL594/ka7500 driver IC. In the attached photo, the top waveform shows a good drive signal. The bottom waveform shows a bad drive signal produced due to a defective driver transistor.
Also check the gate resistors for each of the power supply FETs.
Hifonics BXI608 repairHide this!Advertise here!
Hifonics BXI608 repair greg_gorrell Class D 0 17th March 2010 05:02 AM
Hifonics Eros Perry Babin Car Audio 8 28th December 2009 06:08 AM
Hifonics BX1000D Dobermann Car Audio 2 26th September 2008 04:27 PM
Hifonics Problem swordfish689 Car Audio 5 2nd April 2007 03:49 PM
Hifonics Cupid Lasse- Car Audio 3 5th February 2004 10:28 PM
