Go Back   Home > Forums > General Interest > Car Audio
Old 17th March 2010, 05:27 AM   #1
Default Ppi a600
The power supplyu in this amp is blown. The fets in it are SMP25N06.
Is there a good replacement (sub) for theese?
Also what ohm resistors are they using for the gates. Since evryone in this amp is toast
Old 17th March 2010, 06:19 AM   #2
The gate resistors are 100 ohms, most likely. I'd try the IRFZ44. The IRFZ34 is generally a drop-in replacement for the 25N06s but The Z44 should be OK. If you use the Z44s, monitor the temperature of the power supply FETs for about a minute after replacing them. If they remain cool, you shouldn't have to make any other changes.
Old 20th March 2010, 10:47 PM   #3
The NDP7060's wouldnt work would they?
Old 21st March 2010, 01:44 AM   #4
If I'm not mistaken, the driver IC drives the FETs directly. I don't know if it can reliably drive 8 7060s. Long term reliably could be a problem.
PPI A600 improvement manina Car Audio 7 3rd April 2009 03:16 AM
PPI A600 problems Riveted1 Car Audio 5 29th January 2009 08:35 PM
Ppi A600 npenson Car Audio 4 27th August 2008 10:36 PM
Upgrading a PPI A600.2 MazdaBoi Car Audio 6 12th March 2008 07:47 PM
PPI A600.2 Troubleshooting Help digitalloving Car Audio 4 17th August 2007 07:26 AM
Page generated in 0.07130 seconds (72.35% PHP - 27.65% MySQL) with 10 queries
